It is currently Mon May 25, 2026 5:32 pm
 Post subject: need advise
PostPosted: Fri Sep 09, 2005 11:54 pm
wat is a good way to add a couple horse to my 1.8 motor without spending a lot of cash
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sat Sep 10, 2005 9:28 am
is it completely stock now? how much is a lot of cash?
Resident lurker
PostPosted: Sat Sep 10, 2005 9:59 am
-250 is mybuget
79 4x4 1.8 liter
PostPosted: Sun Sep 18, 2005 11:29 am
can any body help
79 4x4 1.8 liter
PostPosted: Sun Sep 18, 2005 6:14 pm
Header and bigger exhaust pipe (2 inch to 2 1/4) would help. Weber carb will help some more. You could get a camshaft regrind, I think Deltacams has something for the 1.8L.
A good tune up (plugs, points, cap and rotor at a minimum) will help if it hasn't been done in a while. Changing the fluids can also be a help, tho barely noticable. (Engine oil, trans oil, axle lube)
You could upgrade to electronic ignition also, that would help not only power but just in general.
PostPosted: Sun Sep 18, 2005 6:34 pm
What he said. A weber made a big difference in my little stocker.
Resident lurker
PostPosted: Sun Sep 18, 2005 7:10 pm
how much is those carbs
79 4x4 1.8 liter
PostPosted: Sun Sep 18, 2005 8:17 pm
Banishment Pending
Brand new kit with every thing will run ya about $350 or so, they do have them on Ebay every now and then for a good price.
PostPosted: Sun Sep 18, 2005 9:42 pm
crow cams makes a cam for these little motors. its made for the gemini but its the same motor
http://www.crowcams.com.au/templates/Ca ... -OHC.shtml
PostPosted: Tue Oct 25, 2005 10:34 am
I like the idea of the Weber. It does take alot of guessing out of the pile when you have a carb that don't get gunked up with crap and puts more air into the chamber.
PostPosted: Tue Oct 25, 2005 10:37 am
Your 79 won't pass smog in Ca. with a custom carb on it.
You could do the exhaust stuff as long as you leave the cat in there.
