It is currently Mon Jun 29, 2026 10:46 am
 Post subject: generator?
PostPosted: Mon Oct 24, 2005 1:28 pm
I know nothing about generators. The charge light went on and two days later there was no jucie. Now my truck won't stay charged. Where do i get a genetator for a 77? :?:
PostPosted: Mon Oct 24, 2005 8:18 pm
Just about any parts place!
PostPosted: Mon Oct 24, 2005 8:41 pm
If you want a good Generator. Get one out of an 84 Izusu Trooper. I think that one is a 50 Watt, which generates more power and you don't have the surges that the old 35W has.
But be careful. You can burn out some schtuff.
Your local NAPA, Advance, AutoZone - Prefer the other two over AutoZone might even have one in stock.
 Post subject: generators
PostPosted: Mon Oct 24, 2005 10:34 pm
Don't be surprised if the problem is the voltage regulator. A bad one can keep an alternator from charging the battery.
PostPosted: Tue Oct 25, 2005 10:13 am
True - you can beat yourself mindlessly over the head with a tire iron and it may not even be the item you need.
PostPosted: Fri Oct 28, 2005 2:19 pm
So the generator is not the alternator? I can't find generators anywhere on line. I appreciate the help. My login name should be "dontknowshit" Ha!
I got an Advance by my house i'll check with them.
 Post subject: alternator
PostPosted: Fri Oct 28, 2005 6:05 pm
For your understanding: Originally vehicles we have driven over the years started with 12 volts direct current. (12VDC) Nowadays vehicles use alternators that produce 12 volts alternating current. (12VAC) But the rectifiers on the collector ring inside the alternator housing change into it into direct current (DC) to charge your battery and run all the electrical equipment. So you see, it just a matter of semantics.
Here's a URL to Advance for an alternator for a Chevy LUV.
http://www.partsamerica.com/ProductList ... Alternator
