It is currently Wed Jun 24, 2026 12:30 pm
 Post subject: Tranny trouble
PostPosted: Fri Oct 21, 2005 8:08 am
Does anybody know there whereabouts of a bellhousing for an S-10 diesel pickup? I am out of trannys on my LUV diesels and need to adapt something. Anybody got any other ideas?
always always lots of work to do. . .
 Post subject: luv tranny
PostPosted: Fri Oct 21, 2005 12:15 pm
I recently bought a pile of automotive parts which included what the owner said was a diesel luv tranny. I know it will bolt up to a C223 motor, because I tried the other day. I can post pics so someone more knowledgable may positively ID it. What do you have to swap?
 Post subject: Isuzu Transmissions
PostPosted: Sat Oct 22, 2005 12:07 am
Dan--
I have found that most times these transmissions can be repaired by replacing the bearings which are bad (it would be wise to replace all the bearings at once) and nothing more. So, if you have a stockpile of bad ones, perhaps you could practice up on one of them. The Isuzu shop manual is quite good at guiding one thru this job. You would need gaskets and seals too.
Paul
'84 Isuzu diesel P'up
PostPosted: Sat Oct 22, 2005 8:40 am
Paul, thanks for your insights. I agree--however in this case the countershaft has gone bad and a couple of gears are missing. I am very interested in making an adapter plate that will allow GM (t-5 for example) trannys to adapt to the Isuzu motor via GM bellhousings. Of course will require diffrent flywheel, starter, clutch etc. It seems to me this is a vehicle with a world class engine, and a lousy tranny.
