It is currently Fri May 01, 2026 7:46 pm
 Post subject: Transmission?
PostPosted: Wed Oct 05, 2005 10:14 pm
I just got a 1982 Luv Diesel with a 5 speed manual. After about 200 miles while driving down the freeway at about 65 it went bang and started slowing down. I down shifted to 4th and made it the 4 miles to the exit where I had to stop. After that it wouldn't move at all. Any suggestions where to start?
Thanks
PostPosted: Thu Oct 06, 2005 12:18 am
injector timing and valves is where i would start.
PostPosted: Thu Oct 06, 2005 7:15 pm
The engine runs but I have no gears.
Greg
PostPosted: Thu Oct 06, 2005 7:28 pm
snapped input shaft, mainshaft, blew the clutch disk???
PostPosted: Thu Oct 06, 2005 8:13 pm
Possibly a transmission bearing failure...which may have caused other disasters. I believe these transmissions were subject to bearings giving out.
It sounds similar to what I had happen to a 1976 Celica I had once.
Was the transmission quieter in 4th gear? I ask this because 4th is a direct gear (I think) and doesn't use the secondary shaft in the tranny, on which a bearing may have failed. There are others on here that certainly have experience with these transmissions.
Bona Fide diesel fanatic.
1994 Chev S10 Ext Cab Isuzu Diesel 5spd
Kubota B6100 HST diesel
PostPosted: Thu Oct 06, 2005 10:20 pm
The truck wouldn't drive in 5th, after the bang it started slipping. I put it in 4th and it went till I came to a stop sign where once stopped I couldn't get any gear so I towed it home. Tomorrow I'll get it off the trailer and see what I have.
Thanks
