It is currently Tue May 26, 2026 7:40 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Aug 20, 2005 12:59 am
Thanks alot guys. :D
It's time to talk about engines. I originally intended to just use a good 'ol 20 or 22r toyota motor and it would be fine. Except that it would be just like every other toyota out there :roll: . You have to plan your passes a half mile ahead of time; Downshifting to climb hills; then add a/c into the mix 8O . No, that just isn't going to cut it. There are lots of swaps that can be done to a Toyota and lots of adapters and things made by various companies. What engine will be going into this truck you ask?? :?
Stay Tuned..... :wink:
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Sat Aug 20, 2005 3:51 am
Swap Specialist Mod
my dad has a 82 toyota that has a buick 225 v6 in it. i guess the guy that put the motor in they truck used a kit that had motor mounts, a tranny mount and a transfercase adapter. now when a toyota body is used there is no modifacations to the firewall. i dont know about the luv body on there. its looks like the mounts for the body have bodylifted the truck, so i dont think youll have any problems with clearances.
PostPosted: Sat Aug 20, 2005 12:43 pm
The 20 and 22r engines have around 100 HP and the EFI 22re has around 115 or so. In order to make this truck fun to drive through hills or flatland, with or without a/c running, we're going to need about double that. Here is a picure of my new engine stand :lol:
This is a 1983 Toyota
That has been kind enough to agree to donate it's engine, harness, computer, bellhousing, radiator, a/c parts, cruise control, and other stuff to the truck build. :wink:
It has the Toyota 5MGE engine which is a DOHC inline 6 EFI producing about 150-160 HP in stock form. I'm not sure of the torque rating but with the DOHC's it runs nice! I'm going to remove all smog junk, add a cold air intake, free flowing exhaust and header and possibly some cams. That should put the numbers real close to 200. :smt023 . I've researched the swap and it is fairly common in toyota truck circles. It's not going to be easy to fit in the Luv engine compartment which is slightly shorter than the Toy truck bay but it can and will be done :wink: You are probably wondering what trans, t-case etc. ...I will provide all the details of the swap as I go.
PostPosted: Sat Aug 20, 2005 5:28 pm
Banishment Pending
:shocked!: :shocked!: :shocked!: :shocked!: :shocked!: :shocked!: :shocked!: :shocked!: :smt103 :smt103 :smt103 :smt103 :smt103
DUDE!!!!!!!! that thing is going to haul ASS!!!!!!!!!!! :twisted: :twisted: :twisted: :twisted: :twisted:
now if only I could get one :roll: but with twin turbos :twisted: :twisted: :twisted: :twisted:
PostPosted: Sat Aug 20, 2005 6:27 pm
Swap Specialist Mod
shouldnt that supra motor bolt right up to the exsisting 4x4 toyota tranny. im pretty sure it should. ive seen other 2jz swaps into like toyota PUs and 4runners and they just bolt the motor right up to the exsisting tranny and off they go.
anyways, that gonna be really trick when you get it done.
PostPosted: Sat Aug 20, 2005 9:18 pm
Banishment Pending
I don't think the stock toyota trans would handle the supra engine's power, but then of course i'm just going off of info i'v gotten from others, but then again they had turbo setups and not N/A, so i could be wrong about the stock tranny handling the power.
PostPosted: Thu Sep 22, 2005 9:44 pm
Things have been going pretty slow but I managed to get a few things done in the past few weeks.
First of all, The Supra motor is out. The Luv engine compartment is shorter than a Toyota truck and I just wont be able to fit it in there without recessing the firewall and I am not going to do that. I've decided to go with a Toyota 4 cylinder truck motor and just put some power upgrades on it.
I found a near perfect set of stepside fenders for it.
:smt023
There is only one minor cracked area on one step but it's not a through-break ...a super easy fix and none of the edges have been broken or repaired. Amazing
Last edited by Feelin the Luv on Thu Sep 22, 2005 9:51 pm, edited 1 time in total.
PostPosted: Thu Sep 22, 2005 9:48 pm
A pretty nice Mikado steering wheel
And I've cleaned up and painted the engine compartment with Hammered finish paint. never mind the color...the body color (unknown at this time) will go over the top of it.
More to come...
PostPosted: Thu Sep 22, 2005 10:05 pm
that's looking pretty sweet... makes me feel guilty about how mine looks 8O
PostPosted: Thu Sep 22, 2005 10:10 pm
Swap Specialist Mod
i know tis is kinda off topic, but would that supra motor fit in a older toyota pickup? ive always wanted to get like a 81-83 toyota 2wd pickup and put a tricked out motor in it. ive seen the buick swap done alot, but i wanna see a supra motor in a 2wd pickup.
PostPosted: Fri Sep 23, 2005 1:35 am
Yep. It's been done quite a bit. Check out Supracharged.com for more info :wink:
PostPosted: Sat Dec 17, 2005 6:27 am
November 25th was Marios last post. WHERE YOU AT??????? I wanna see some pics, damn it! :twisted:
PostPosted: Fri Dec 30, 2005 11:08 pm
Yea, I'm pretty interested in this project! How's the progress going?
'46 Studebaker truck "project"
'90 Trooper 4X4, 2.6L 5 spd
PostPosted: Sun Feb 19, 2006 11:58 pm
very cool project! i'd highly recommend the crossover steering setup, i've got it on my '79 toy and it makes things less scary on-road, and performs better off-road.
to bolt that supra engine up you're gonna need a tranny from a '84-95 4cyl toyota, and the supra bellhousing. only thing there is that you're gonna have to relocate the crossmember and resize the drivelines, as the later tranny is 4" longer than the '79-83 box.
oh yeah, and my 20R/22R hybrid doesn't require any downshifting on hills. power on demand, baby :twisted:
PostPosted: Sat May 20, 2006 8:54 pm
I was looking through old posts and saw this one. I was wondering where this truck is now. Is it finished? Was it set aside? Just curious.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sat May 20, 2006 9:40 pm
Mario hasnt been on in quite some time. I hope all is good :roll:
PostPosted: Wed Jun 21, 2006 8:13 pm
I guess no one knows about this truck. I would really like to know how it turned out.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sat Jul 29, 2006 11:36 pm
sorry i did not see that the luv---toy 4x4 was that old but it was sweet how did it work out
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sat Jul 29, 2006 11:42 pm
budbondo...
there are a couple of decent fleetside beds in the local yards over in Lemoore if you're interested i can give you the name and number of the place
HOORAY!!!!!!!!!! 2000th POST
PostPosted: Sat Jul 29, 2006 11:50 pm
that would be great i saw that 4x4 and think i am going to save the life of my little stepside bed i got sum full size a cut here &a cut there sum work alot but i think it will be good thanks
dangerous-toys4life
75 k-5 2x
94 king cab
Users browsing this forum: Google [Bot] and 30 guests
