It is currently Sun Feb 01, 2026 3:32 pm
PostPosted: Sun Sep 18, 2005 8:33 pm
Luvtruck.com Wookie
okey dokie......so i'm building this v-6 setup for my 80......
does anybody know if i can bolt the 2.8 bellhousing up to a t-56(6spd)?
i got a buddy that has a wrecked 97 camero(V-8 + T-56) and will give me the trans for $200, if the bell housing bolt pattern for the t-5 is the same i'd luv to gear my luv with it. i however can't afford to go get it if it just won't work.
i'll be running a s-10 rear w/3.73 ratio and posi
TiLtEd wrote:
Boobies!!! :D
Last edited by where's all the luv at? on Wed Sep 21, 2005 8:42 pm, edited 1 time in total.
PostPosted: Mon Sep 19, 2005 9:14 am
2.8 has a different pattern than a small block. the 4.3 was the same but if I am not bad wrong the .28 was not the same so it would not work
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Mon Sep 19, 2005 12:53 pm
i think his question is if the tranny will bolt to the bellhousing not if the bellhousing will fit the block...
PostPosted: Mon Sep 19, 2005 7:45 pm
Luvtruck.com Wookie
you got it................
TiLtEd wrote:
Boobies!!! :D
PostPosted: Mon Sep 19, 2005 7:52 pm
on one of the camaro sites they are swapping t-56's in place of t-5's on v-8 cars. I guess it's about input shaft length, and input shaft splines for the clutch. I believe the pattern to the belhousing would be different also as they swap the bellhousing when going from t-5 to t-56. If you check on some camaro sites, you might find more info.
