It is currently Thu Mar 26, 2026 9:31 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
PostPosted: Sun Sep 11, 2005 6:47 pm
Luvtruck.com Wookie
alright, i have the engine bay harness out.....i got the dignostic harness out of the cab. i have the ecm hooked up to the harness properly. but the fuse box side of the harness has me lost.
where do all these damn wires go? i need a diagram bad.....who's got a book? who can scan the wiring diagram for the 86 blazer 2.8 and send it to me?
i know where one of these wires go and that's it. these guys can really confuse the hell out of ya and i'm lost.
TiLtEd wrote:
Boobies!!! :D
Last edited by where's all the luv at? on Sun Sep 18, 2005 5:55 pm, edited 2 times in total.
PostPosted: Sun Sep 11, 2005 8:59 pm
I got a haynes manual with some wiring diagrams in it. which ones you need?
PostPosted: Sat Sep 17, 2005 7:09 am
Luvtruck.com Wookie
alrighty.... i have the engine running on the stand as we speak....
i'll be posting a key to where all the wires go from the 2.8's quick disconnect into the luv's stock wiring harness. time to fab a set of mounts.
maybe when i'm done i'll do a writeup on this subject.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sat Sep 17, 2005 3:27 pm
Swap Specialist Mod
ok, so clear me up now. ok the tranny in the luv locked up, right? so you pulled the motor and tranny and your putting a 2.8 in the luv? or an s10blazer? im so very confused :?:
PostPosted: Sat Sep 17, 2005 6:06 pm
luv 5 spd locked up on him, so now he's pulling engine from an s-10 blazer and stuffing the 2.8l into the luv with the tbi and all the smog stuff in an attempt to get smog legal.
PostPosted: Sat Sep 17, 2005 7:00 pm
Banishment Pending
New Luv though, the one getting the 2.8 TBI is a 4x4, the one that trans locked up on was 2wd
PostPosted: Sat Sep 17, 2005 8:10 pm
and there you have it... :wink:
PostPosted: Sat Sep 17, 2005 9:29 pm
Banishment Pending
yupers
PostPosted: Sun Sep 18, 2005 4:20 am
Swap Specialist Mod
ohhhhhhhhhhhhhhhhhhhh. mkay
PostPosted: Sun Sep 18, 2005 1:09 pm
Luvtruck.com Wookie
nope........i guess i should've mentioned at the beginning, that i yanked the front end out of another 2wd luv upper control arms to knuckes and will be replacing and straightning the broken parts in the 80 2wd i wrecked.
the crossmember that got toasted was the one between the lower front suspension, the tortion bar and tranny mount crossmember just got dinged up pretty good.
i have bigger plans for my 4x4.......
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sun Sep 18, 2005 1:48 pm
Luvtruck.com Wookie
here we go.......
here's the sitting positin, as you can see i've choped the front clip a bit. more for a bigger radiator than fittiment issues. i'll be welding a new clip from some body steel i scored.
i'm keeping the charging system from the blazer since it's one wire......
however i had to chop the battery tray for the alt and smog pump to clear.
the motor doesn't really line up to the stock mount pads........here's the position. i've allready designed the mount plates, but alas, i do not have a scanner to post them.
i'm having one problem..... the motor sits too high. i won't be able to align the transmission if i install the motor first. i think i've found a way around this, but i'll have to wait for the machine shop to open on monday.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sun Sep 18, 2005 2:05 pm
i guess we stand corrected. 8O
it looks good sitting in there and i can't wait to read the full write up on this one... :D
PostPosted: Sun Sep 18, 2005 2:19 pm
Luvtruck.com Wookie
here's the wiring key from the disconnect at the firewall. if you remove the harness yourself(donor vehicle), pull the fusebox out of the way and cut all the wires aprox 10" from the disconnect. i've eliminated all the unnessary wiring from the harness already.
a-1 stop switch(auto trans, unneeded for a 5spd) : a-2 voltmeter
b-1 to computer(diag harness, inside vehicle): b-2 to ignition fuse 20A
c-1 2 leads, run side of ign switch and keyed hot to fusebox: c-2 12volt to cpu 10A fuse, keyed to run position
d-1 2 leads, direct headlight power, to secondary lighting fuse: d-2 oil press gauge
e-1 to fuel pump: e-2 temp gauge
f-1 check gauge light : f-2 main hot from batt/alt combination
g-1 12volt to computer, fuzed 10A ,batt: g-2 upshift light(unused)
h-1 2 leads from start position of ign switch to engine via clutch start, to start positon of fusebox: h-2 start signal to computer fused @ 3A
all wires to lights and meters are ground side meaning they are supplied power from a 20A fuse and then connect to the harness
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sun Sep 18, 2005 2:24 pm
that's good info right there.. keep us posted..
PostPosted: Sun Sep 18, 2005 8:15 pm
Banishment Pending
I stand corrected!!!! wow that info with the wiring, thats some good stuff there!!!! keep us posted on how things work out!!!
PostPosted: Fri Sep 23, 2005 9:34 pm
Luvtruck.com Wookie
got these back today........
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sat Sep 24, 2005 11:00 pm
Banishment Pending
Nice looking mounting plates :lol:
PostPosted: Sun Sep 25, 2005 2:26 pm
Will the pinion angle be close enough with the fabbed mounts? Or are you going to change the rear axle soon after and match it to the motor setup? From the pic, it gives the illusion that the front of the motor will be pointing up somewhat. If need be, using wedges at the leaf springs could get the pinion angle within 3 degrees. My truck made a howling noise with over 10 degrees misalignment. You might want to look in to that before you get to commited to the motor mounts.
PostPosted: Mon Sep 26, 2005 7:55 pm
Luvtruck.com Wookie
it's all cool. i don't have the trans bolted to the engine yet so it sits in the bay leaning back. all in all the level line from crank to talishaft has only changed by 3/8", i want to lower the engine a bit(2") but i think i'd need to alter the trans cross member too.
i was having an issue with the height of the engine when it sits level though, i'm probably gonna need a hood scoop to make enough clearance for the air cleaner. i have 2 1/2" i can go down, but that would require custom motor mount brakets on the engine. the mounts are the pin through bushing type and there's room to re drill them to lower em about an inch, but if i'm gonna do that i want to go all the way. either way i'll still be using the plates (eventualy i'll be welding legs where they overhang the old mount blocks).
BTW.......i'm swaping the blazer rear in also.....
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Sep 29, 2005 5:41 pm
Banishment Pending
Any up dates on the 2.8 swap?
