It is currently Mon May 25, 2026 7:43 am
 Post subject: dana 44
PostPosted: Mon Sep 05, 2005 2:18 am
hey guys i was thinking of putting a dana 44 in the rear of my 1974 luv but i dont know if it will be big enough? if you could help me out guys that would be great
PostPosted: Mon Sep 05, 2005 2:40 am
well it all depends on what your running. Just bear in mind its a 28spline axle whith a 8.5" ring gear and 10bolts for the ring gear to the carrier and it usues C-clips for holding the axles (unexceptable for a high performnce v-8 in my eyes). Its identical in most working dimensions to a GM 10 from a truck.
PostPosted: Fri Sep 09, 2005 5:06 pm
Japanese Redneck
Dana 44's can hold up to medium-high performance. full race needs a 9er. that white luv down in houston does low 9's on a dana 44 out of a mail jeep.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Fri Sep 09, 2005 5:18 pm
thanks for he help guys i am going to usa that dana44 i got
PostPosted: Mon Sep 12, 2005 10:06 pm
Japanese Redneck
btw the center chunk of the IRS in a most vettes is a dana 44. NHRA will certify a vette IRS down to 9.00 when the mandated upgrades are made. they can be built to perform
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Mon Sep 19, 2005 6:06 pm
GOT THE DANA 44 FROM JOSE LUV IN MINE NOW BEEN MID 9'S NO PROBLEM BUT IT IN THE CHASSIS SHOP FOR CAGE AND LADDER BARS UPDATES :D MOSER AXLES AND SPOOL DANA 44 HAVE NO C-CLIPS 6 BOLTS HOLD IT TO HOUSING HOPE THIS HELPS
Users browsing this forum: Bing [Bot] and 23 guests
