It is currently Sun May 10, 2026 3:28 pm
PostPosted: Wed Sep 07, 2005 1:16 pm
Hey guys i did a search but didnt really find what i was looking for i want to put front disc on my luv but i cant find what i need. i was wondering if i get the 76 front set up will it work for me . spindles brakes calipers all the goods. if any one can help me out that would be sweet thanks guys
PostPosted: Wed Sep 07, 2005 4:42 pm
I don't know if you've seen it or not, but there is an article on this in the "information" section of this site or just click this:
http://www.luvtruck.com/PDF/LUVDiscBrakes.pdf
Hope that helps.
1980 2wd Stock
PostPosted: Wed Sep 07, 2005 6:58 pm
Luvtruck.com Wookie
don't forget luv restoration's disk swap kit.........i'd prefer to go that route after i save the cash.....
TiLtEd wrote:
Boobies!!! :D
PostPosted: Mon Sep 12, 2005 12:55 am
I did the front brake conversion on my 75 it was a peice of cake. I went to the local pick and peel wrecking yard and talked to the owner he didnt know much about it so he went out and pulled the spindles and everything attached. I threw away every thing but the caliper brackets, rotors and dust shields on my way home from wrecking yard I stopped at Kragens autoparts and ordered new calipers, pads, hoses and bearings. Its pretty strait froward pull the wheels off then the drums and the four bolts that hold the backing plate on and then put the rotor dust shields on and then caliper brackets and tighten the bolts. I think it took me about an hour and that was with one of my friends talking the whole time and drinking a few beers.
Users browsing this forum: Bing [Bot] and 27 guests
