It is currently Sun May 31, 2026 7:50 am
 Post subject: Pictures
PostPosted: Sat Feb 08, 2003 12:53 am
OK everyone, there are some more pics of the progress on my truck. Look at both Rick and Hugh Acosta. They are of the same truck, but the pics are separated. I will have to get them in ONE spot. What you see here is some modification to the front to install coil springs and remove the torsion bars. Right now the truck is sitting on the springs and seems to be just about right. I have the cab and bed in place and need to bolt the fenders on so I can check the tire clearance. More pics to follow....
Rick
PostPosted: Sat Feb 08, 2003 10:41 am
Ok, those pictures look great. can you give a little more detail on what we are looking at. did your raise the stock shock mounting location by fabbing in some mounting pieces from a donor truck, in turn lowering the front end? If so, why so tall? is it to fit in a larger coil over set up.?
i ask because whaterver your doing looks well thought out. Id like to do the coil over thing to reroute my exhaust(my floor melts my shoes practically) past where the T bars are now. Id hate to go into it blind. If youve had a discussion on this, whats the subject.?
thanx, dave.
g
Users browsing this forum: Google [Bot] and 33 guests
