It is currently Wed Mar 25, 2026 7:48 am
PostPosted: Tue Dec 17, 2002 11:58 pm
Does anyone know what problems I could run into with this set up. I am considering this set up rather than a automatic because I prefere manual transmisions. However I haven't found anything about it here. Has anyone done this? :?: :?
PostPosted: Wed Dec 18, 2002 2:13 am
I'm sure it's doable. You may have to do a little custom work to the tans tunnel with a hammer. Not sure though. I know a 4-speed fits so I assume a 5 will too.
I was tossing around a similar idea recently. I'd like to have overdrive again but I couldn't get a 700R4 to live.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Wed Dec 18, 2002 7:58 am
I had a 5 speed with the V6.
you might have to fab a crossmember for it to work.
and yeah.....a little beating on the trans tunnel.......
hey look! someone else in Tennessee!!!! WHoo h00!!!!
03Cobra
PostPosted: Fri Feb 07, 2003 12:32 am
Older post.if the T5 trans is out of a camaro or firebird with a V8 5spd.Don't put the 5 spd in.It won't hold up to and horsepower! I was going to go 5 spd but a close friend told me how I drive,Put AT in it.You'll hurt less parts.That was 18yrs ago.But when you get in the truck,age doesn't mean a damm thing
PostPosted: Fri Feb 07, 2003 10:42 pm
Get a T56 out of a vette 8O The new ones are like 400+ horsepower and should hold up to whatever you throw at it. Plus a whole extra gear!
PostPosted: Sat Feb 08, 2003 1:44 am
uhh... correct me if i'm wrong...but doesn't the newer vettes have a special trans thats mated to the differential in the back.
PostPosted: Sat Feb 08, 2003 11:23 am
The corvette does mate to rear end.I looked at the camaro/firebird 6spd is plenty strong enough,but the shifter is located in the very back of the tailshaft housing.I work for a major auto dismantler in the area,so I was able to look at one out of the car
PostPosted: Tue Feb 11, 2003 7:52 pm
I was gonna stick a T5 in my 67 chevelle, but I found out there is 2 different kinds of T5's (for camaros/firebirds anyway). The one that I have is off of a v6 camaro, I was told that it won't take the power. But... There is another T5 that came on the v8's. Its called a T5 World Class, from what I'm told this should take the power. I've seen a few of the world class T5s for sale in the paper, so they are real. This is just what I'm told anyway, don't beat me. :x
PostPosted: Wed Feb 19, 2003 2:17 am
A Word Class t-5 will hold up. I had one in my small block 72 Vette.
I beat the hell out of that thing and it never gave up.
When everthing goes wrong....
What's right is what's left.
