It is currently Fri Mar 27, 2026 2:00 am
 Post subject: power windows
PostPosted: Sun Aug 07, 2005 10:55 pm
To keep with the old school them I found an old school power window kit made by Norton from 1980 never installed but he did start to put a couple peaces together. I started to install it today. so far so good. This is the kind where you take off the window crank handle and attach the motor gear to crank, motor then cranks the window for you. Well let you know how it turns out.
PostPosted: Mon Aug 08, 2005 7:09 am
cool, let us know how it works out.
RIchard
PostPosted: Mon Aug 08, 2005 10:35 pm
Well I have one door with the motor in and wired up so far and everything works good
Here is what it looks like so far
This is how motor end attaches
The motor has to go in the right side by the bottom hinge that’s where the most room is
And these are the cuda switches I’m going to use instead of the cheap plastic that came with the kit
I'm also going to install a power antenna that is operated by a single Cuda switch so I can raise or lower it when ever I want and not just when the radio is on or off
PostPosted: Mon Aug 08, 2005 10:57 pm
you got any more specific info on the kit you are using. You said it's a Norton and old school....
PostPosted: Mon Aug 08, 2005 11:08 pm
it was norton out of dallas texas the copy right said 1989 I thought it was 1980 I have a 1980 truckin mag with this kit in it so they where at least in business then and I got tis off ebay have seen a few since then too its universal and i don't see a model # anywhere
PostPosted: Mon Aug 08, 2005 11:12 pm
thanks.. guess i'll have to go on the hunt
PostPosted: Tue Aug 09, 2005 3:41 am
geez ctmandu, your goin all fancy on us!, first that fancy carb now power windows!. lol jk, looks great. let us know how it turns out. :wink:
PostPosted: Sun Aug 14, 2005 7:44 pm
Well I got a little further today and have one side all done and the power antenna wired in also all I need to do now is mount the motor in the passenger side door and hook up the 2 wires and it will all be done. The driver side works great.
Image the bottom switch is for the power antenna
PostPosted: Sun Aug 14, 2005 8:14 pm
to fricken cool. Good job, wish I had power windows :cry:
PostPosted: Sun Aug 14, 2005 11:00 pm
thanks, i like it and it almost looks factory, if they would have done it
PostPosted: Mon Aug 15, 2005 5:42 am
Very Nice.!!!
PostPosted: Mon Aug 15, 2005 6:47 am
Was there any seirial number or part number on the box or instructions... you could just google the number and see if any sites still carry some.
PostPosted: Mon Aug 15, 2005 8:28 am
not in original box and no serial # on instructions or warranty card sorry. if you guys dont care if its old shool or not then look here
http://search.ebay.com/power-window-kit ... ageZsearch
PostPosted: Mon Aug 15, 2005 10:57 pm
well its all done and in working order. now off to the next project on the luv wich will be installing this flip open gas cap and side marker lights :lol:
PostPosted: Mon Aug 15, 2005 11:19 pm
i see someone has been stripping a mopar...
PostPosted: Mon Aug 15, 2005 11:34 pm
yep, how did you ever guess :lol: :lol: :lol: they seam to have the best old shool looking stuff and i've seen a couple of luvs in the old truckin mags with this gas cap and thought it looked pretty cool so I figured why not.
PostPosted: Mon Aug 15, 2005 11:40 pm
had a few mopars back in the day.. seen folks recess that gas cap and it looked great..
PostPosted: Wed Oct 26, 2005 8:09 am
What are those side markers off of? They look sweet!
PostPosted: Wed Oct 26, 2005 9:02 am
68 mopar dodge, plymouth, chrysler. they are 1968 only, some are flat some with slight curve. the 68 dart had a curve to them not sure witch ones had the flat ones
