It is currently Thu Mar 26, 2026 6:32 pm
PostPosted: Sun Jul 31, 2005 4:44 am
how did you hook up the factory speedo with a th350? im looking at doing a v8 in my 83 pup but im not to sure about the speedo. any help will be of use
thanks
kevin
PostPosted: Sun Jul 31, 2005 6:38 pm
on my 80 the stock cable hooks up to the th350
PostPosted: Sun Jul 31, 2005 11:53 pm
how accurate is it?
PostPosted: Mon Aug 01, 2005 12:48 am
Swap Specialist Mod
in pee roy's truck it was about 10-15 mph faster.
PostPosted: Mon Aug 01, 2005 12:53 am
thanks for the info guys! i know that my dads old th350 had some sort of gearbox that screwed right into the tranny and then the cable screwed into the gearbox. maby i could find a box that would work cuz i know that they made different ratios for the boxes
PostPosted: Wed Aug 03, 2005 2:27 am
it also depends on ur differential when i had stock diff. it was like 15-20mph faster with s10 diff about 10mph faster
PostPosted: Wed Aug 03, 2005 6:01 pm
well then i should expect about 10 mph faster because im gettin an s10 diff.
thanks for the info.
kevin
PostPosted: Thu Aug 04, 2005 1:30 pm
Japanese Redneck
I believe VDO carries an adjustable universal speedo. you can connect it to your GM speedo cable (you may have to get one out of a different car) and use a dial to calibrate it.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
