It is currently Mon Jun 08, 2026 7:10 am
 Post subject: Dome Lights?
PostPosted: Mon Jul 04, 2005 4:30 pm
does anybody know of any dome lamps i could put in my truck? the hole is pretty small, but i guess i could cut it bigger. somebody before me took the original lamp out, if it ever had one.
PostPosted: Thu Jul 14, 2005 1:30 pm
I found a couple of dome lights in wrecking yards but the plastic on the switches have began to crumble, so I'm still without a dome light. I also looked into after market lights but have not found anything small enough. Sorry I could not be of more help, if you come up with something please post it. Thanks
PostPosted: Thu Jul 14, 2005 5:16 pm
I used an old license plate light,cut a tiny hole in it and mounted a switch from radio shack its pretty close to the same size and its bright
Dr. Frankenstein
PostPosted: Mon Jul 18, 2005 10:44 pm
Go to Advanced Auto Parts
They have a one size fits all interior dome light with a chrome bezel
and an on off swith.
It fits ALmost into the stock holes just a little rounding with a dremel and they will fit like a glove. AND they are bright too.
Note hook the lights ground wire into the stock screw hole
