It is currently Sun Dec 21, 2025 11:58 pm
Post new topic Reply to topic  [ 76 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Thu Jun 16, 2005 1:37 am
Well, as some of you may know, I have a plan to put a 75 Luv stepside body on a 82 Toyota 4x4 chassis and drivetrain. I have finally gotten started and want to document the build with lots of info and pictures.
First off, I have pictures of the Toyota donor truck. Run of the mill 1982 shortbed 4x4
Here is the 1975 Luv truck donor.
So far, I have the body off of the Toyota. I am wire-wheeling and brushing all the grime and old paint out of every nook and cranny of the frame. These pictures are before I started cleaning.
Dig this shock 8O .
Thats it for now. More updates to come. :wink:
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Thu Jun 16, 2005 6:25 am
you picked a good luv to start with! that thing looks nice.
dood that shock has a bent personality!
good pics man. Good luck with the buildup!
:D
03Cobra
PostPosted: Thu Jun 16, 2005 4:52 pm
Are the wheelbases real close?
Dr. Frankenstein
PostPosted: Thu Jun 16, 2005 5:59 pm
@ 3/4 of an inch difference. The LUV is longer. I plan to compensate for this with a Zero Rate Leaf which will offset the rear 3/4" to the rear.
Raining today so no updates till tomorrow.
PostPosted: Sat Jun 18, 2005 8:17 am
Nice, M.
Resident lurker
PostPosted: Mon Jun 20, 2005 12:19 am
Ok, here is a little teaser for you...
:smt023
Before you get too critical, please remember that the body is just setting on the frame and the front fenders are also just setting. The door-fender gap will close slightly more than is showing. I will be using 3" of body lift built into my mounts. The body will be about 1.5-2" lower than it is now so there won't be so much frame showing. I will be using 32 or 33" tires on the truck and will lift it until I think it looks good. I would imagine about a 4" lift will work. I like alot of tire-fender clearance :wink: . FYI, the tires you are seeing now that are for rollers are 24.5" tall 8O
I have decided to cut my Luv frame down and make a trailer out of it with the fleetside bed. I have been trying to give away a perfectly good motor and trans but since no 0ne wants them, i will use my new trailer to haul them to the metal recycler. :(
The bent shock is starting to grow on me, maybe I'll leave it :lol:
Stay tuned!
PostPosted: Mon Jun 20, 2005 1:15 am
the swap is looking good... very creative and a good choice of drivetrain. toyo's are solid as hell. i think that's messed up about the motor and tranny... i figured someone would have jumped on those. if mine had early style stuff in it, i would have been all over that. when you get your swap done.. throw up a post about what ya got left over and maybe some of us can help clear out your mess... :D
PostPosted: Mon Jun 20, 2005 1:35 am
Thanks. The reasons for using the Toyota was the wheelbase being so close, The aftermarket support for engine and drivetrain is enormous, and, like you said, solid and reliable to no end.
I have 2 ways of going now with my body mounts. The first way would be to cut and weld the mounts into the proper postion. The other is to make the mounts bigger, and design them to be 100% bolt-on. The only reason I consider the larger bolt-on mounts is that I can make a blueprint and jig, then offer those plus every other piece needed for this swap and market it as a 100% bolt-on kit. Alot of people can't or don't have access to cutting and welding equipment. This would be geared toward them. That way, some more Luv bodies will be saved by Toyota owners who want to be different :wink: . What do you all think?
PostPosted: Mon Jun 20, 2005 1:41 am
Damn Mario, just gettin busy with it!!!!!! 8)
PostPosted: Mon Jun 20, 2005 2:10 am
Man, engine and trans to the crusher! Someone should grab that. Did you post an ad in the Classified section? Too bad I live in So Cal or I'd grab that as a spare for my '75.
PostPosted: Mon Jun 20, 2005 8:16 am
i like the kit idea... it would be good to have some options out there for the luv and toyo owners...
PostPosted: Tue Jun 21, 2005 11:33 am
i say you just keep the shocks it has on it and rock those :lol: that looks like a pretty easy swap to do. what running gear are you gonna be using?
PostPosted: Tue Jun 21, 2005 4:23 pm
Toyota axles
PostPosted: Mon Jul 11, 2005 10:52 am
Body and bed mocked on with 31x10.5x15 rollers.
Last edited by Feelin the Luv on Wed Jul 13, 2005 12:00 am, edited 1 time in total.
PostPosted: Mon Jul 11, 2005 10:54 am
Same thing...drivers side
PostPosted: Mon Jul 11, 2005 10:55 am
My (unfinished) super-dope stepside trailer :wink:
 Post subject: stepside
PostPosted: Mon Jul 11, 2005 11:18 am
The septside on the trailer looks familar. hmm :D
PostPosted: Tue Jul 12, 2005 11:26 pm
Ok, I'm starting with the rear cab mounts and working forward. Here are a couple pics to show how far off the stock mounts are between Toy and Luv with the cab in proper position on the frame. These are taken at drivers rear corner. Ratchet is in cab bolt hole for reference.
PostPosted: Tue Jul 12, 2005 11:28 pm
Here is a pic of the roughed out rear cab mount.
PostPosted: Tue Jul 12, 2005 11:37 pm
looks like you got a project on your hands, hope it turns out how you like it, keep all of us up to date on your build up
