It is currently Sun Feb 01, 2026 11:47 am
 Post subject: stereo install prob.
PostPosted: Tue Jun 21, 2005 10:49 am
Hey guys. Got a question. I'm installing a new deck in my wife's van and I'm running into a problem. everything works find until I plug in the antenna cord, then it blows the fuse for the dash lights. I can't figure out what's causing this. Anyone got any ideas?
1980 Luv Mikado 4X4
PostPosted: Tue Jun 21, 2005 12:30 pm
The only thing that comes to mind is that the outside jacket on the antenna cable is a ground. I would guess that's why the antenna seems to be causing the blown fuse, although the real problem is likely something else.
PostPosted: Tue Jun 21, 2005 7:17 pm
Check the wire you used as a ground, make sure that that wire does not have any voltage when the dash lights are on. I have had this problem before, if it does just take that wire and cap it off that is you dimmer light and most after market decks don't support dimmer lights.
Hope that helps
Jim
`79 LUV 2WD Stocky
`80 LUV 4WD Stocky
PostPosted: Wed Jun 22, 2005 10:50 am
Thanks Leroy, that was it. Took me about two minutes to fix it. Thanks a ton. :D See, that's why I keep you guys around. You're so useful. . . :wink: 8)
1980 Luv Mikado 4X4
PostPosted: Wed Jun 22, 2005 11:04 am
glad I could help. It took me awhile to figure it out the first tim I did it.
Jim
`79 LUV 2WD Stocky
`80 LUV 4WD Stocky
