It is currently Sat Feb 07, 2026 7:22 pm
 Post subject: 20" rims?
PostPosted: Sun Jun 05, 2005 7:41 pm
has anyone tried to put some 20" on a luv.will they fit
PostPosted: Sun Jun 05, 2005 11:33 pm
i dunno if they will,and personally the only reason i would ever put 20's on anything would be so i could mount the old 1 1/2 or 2 ton general 35" tires on my truk (cuz we had em' on a freinds bug and the "general brand" tire kik's some serious a$$)
PostPosted: Mon Jun 06, 2005 9:20 pm
I really doubt it without some MAJOR modifications to the suspension and fenderwells. If someone can host a pic for me, I can show you what my dads 20's look like in front of my LUV. 8O
(I dont have access to my webpage now that I am not with that provider anymore. :cry: )
PostPosted: Mon Jun 06, 2005 10:07 pm
Swap Specialist Mod
ill host it
PostPosted: Thu Jun 09, 2005 7:24 pm
Swap Specialist Mod
thems some big ol' rims
neil
PostPosted: Thu Jun 09, 2005 8:32 pm
isnt t-baggin s10 gonna put 20's on that 78? btw that would look PHAT ^
Dr. Frankenstein
PostPosted: Thu Jun 09, 2005 8:47 pm
Swap Specialist Mod
i think he is!
but i think 20s on a luv is a bit much.
neil
PostPosted: Thu Jun 09, 2005 9:29 pm
yeh not my thing either but like on hot rod art,when they draw the huge wheels impossibly tucked... cool to look at on someone elses ride. I still think todays rubber band tires are kinda weird too.
Dr. Frankenstein
PostPosted: Thu Jun 09, 2005 9:37 pm
Swap Specialist Mod
yeah. id rather be tuckin a 14. i mean you can tuck a 20 no problem, but when your tuckin a 14 your DAMN low!
neil
PostPosted: Sun Jun 12, 2005 11:24 pm
sure you can get a 20 to tuck, and I think it would be damn sweet too. but the issue with going that large in diameter is going to be the width. Most 20's are 8.5-9"wide, way too much for our little trucks unless you alter the frame rail widths. So you'd be into it for customer made billets in a 20x7 with a six lug pattern, totally doable but going to be expensive.
My 17's upper lip just barely tuck when my truck is aired out...
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Mon Jun 13, 2005 9:47 pm
I have 235/75/15's on mine now. That's a 28.5" tire. A 245/35/20 would be only 27" tall and would be less than 1/2" wider than my tire. With the right wheel/tire combination, it could be done. Of course, you couldn't slam it.
You went there in that?!?!
PostPosted: Mon Jun 13, 2005 10:44 pm
I found this old thread...
http://forums.luvtruck.com/viewtopic.php?t=4438
As you can see, even an 18 looks big on a Luv. I still think 20's could go in the front....somehow :D .............. :chain: .............. :smt035
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Mon Jun 13, 2005 11:27 pm
i think 18 might be the limit in the front without some solid work on it. but that truck looks sweet with the 18/20's on it
PostPosted: Wed Jun 15, 2005 12:17 am
They look big, not just because they are, but because the offset is not quite right to get it to tuck, plus they are 8" wide wheels.....which is why he has this offset issue.
The width of the wheel pushes the outer lip out near the edge of the fender flares. It actually fills it out nicely but he couldn't go any lower, obviously, but not because of the rim od, its the rim width and offset that got this guy.
My wheels are 17's with 205/45/17s and they tuck, but the fact of the mater is, they dont look like 17's, rim width, offset, and tire sidewall size all plays the part in the illusion.
20's are totally doable, just gotta make sure they are 20x7, which is going to cost some scratch. Plus you'll probably have to cut the inner fender wells to make room for the wheel/tire to pass through if you bag it.
Bagged 84 Pup
Bagged 53 F100
