It is currently Mon Jun 08, 2026 6:44 am
PostPosted: Fri Jun 03, 2005 3:48 am
ok now i put a battery in my luv and went to see if the battery works . but the ingition wouldnt turn, i dont know if its broken or sticking i need help!!!! thnanx
PostPosted: Fri Jun 03, 2005 10:33 am
try some key oil into the ignition with the battery unpluged that should un jam it if that's what it is.
PostPosted: Sat Jun 04, 2005 2:58 am
ok wherre do i buy that i never herd of ignition oil
PostPosted: Sat Jun 04, 2005 6:54 am
just use WD-40 or some lithium grease, silicone spray works too.
Just spray some in, pull the key in and out a few times then try to turn it.
PostPosted: Sat Jun 04, 2005 7:42 pm
ok thnax for the help ill try botth
PostPosted: Sat Jun 04, 2005 9:16 pm
ok nope still sticking could it be that the key is worn cuz it is badly worn but it stil locks and unlocks the doors
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 50 guests
