It is currently Mon Jun 08, 2026 6:44 am
 Post subject: Where is the fuel pump
PostPosted: Mon May 30, 2005 3:48 pm
I have to put another fuel pump on my '81 Luv. I had always assumed it was in the tank, but I was crawling around under it today putting in a shift kit and thought I would look. I found what I think is the pump, but it's in-line. Was that the pump or is it a relay or something?
PostPosted: Mon May 30, 2005 4:35 pm
The pump and filter are both in-line.
PostPosted: Mon May 30, 2005 5:39 pm
It's on the drivers side, foward of the fuel tank on the crossmember. Follow the fuel line back to the tank and you'll find the filter.
PostPosted: Mon May 30, 2005 7:41 pm
Sweet!! That made that job much easier than I thought it would be. Save me some money too, I was going with everything new from the tank forward. Thanks
PostPosted: Mon May 30, 2005 8:15 pm
Swap Specialist Mod
how hard it is to put a shift kit in when it still in the vehicle? also, if the shift kit is in a tranny can you put it in a different tranny? my dad has a hardcore shiftkit in his truck and he doesnt want it anymore. can you put the valvebody from one tranny to another? he wants a stock one and i want the kitted one.
neil
PostPosted: Thu Jun 16, 2005 7:00 pm
The kit was pretty easy to put in. Just drop the valve body and switch out a couple of plates drill a couple of holes, don't loose the check balls :lol: and put it back together.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 50 guests
