It is currently Sun Dec 14, 2025 8:27 am
PostPosted: Thu May 26, 2005 9:40 pm
well i scored on a used 305 out of an El Camino and was wondering what to do with it? put it on my 75 or sell it? ohh yeah it was free :)
PostPosted: Thu May 26, 2005 9:45 pm
Swap Specialist Mod
whats in the 75? the toy motor? heck if it runs put it in the luv and put some tbi on it so you can get some milage.
you should put it in the luv and make it run on propane. here, if you run on propane, your emmisions exsempt. then you can do all kinds of stuff to the motor and never have to pass emmissions.
my dads buick toyota runs on propane and it does really good.
neil
PostPosted: Thu May 26, 2005 10:01 pm
arent you in cali? if its a 75 it doesnt have to get smogged anymore anyway right? Put the 305 in the truck is my vote.
Dr. Frankenstein
PostPosted: Thu May 26, 2005 10:43 pm
my 75 has a diesel title for the past 5 years :) im very intrested in the TPI thing. ohh yeah BTW guys im ganna start going to UTI the 13th of next month :) how much power does 305 have?
PostPosted: Thu May 26, 2005 11:08 pm
Swap Specialist Mod
i think the 305 has like 150hp. the hp rating depends on the year too.
neil
PostPosted: Thu May 26, 2005 11:10 pm
i'd build the 305 mildly and put it in the LUV.. some 416 casting heads ported a bit and a tpi setup and you'd have a decent performer. Nothing huge but a fun street truck.
PostPosted: Thu May 26, 2005 11:12 pm
Swap Specialist Mod
i second that!
neil
PostPosted: Thu May 26, 2005 11:37 pm
can u guys help with some parts so i can put on the 305 for more performance on both power and fuel econ.? also i need some help with wiring the TPI any help will be great. i found this on the net does it make sence?
Baseline: Stock 1977 305 2v................17.30s and 12mpg
Performer intake w/ Holley 600 carb........16.50s and 17mpg
Recurved stock HEI and added Supercoil.....16.30s and 17mpg
Headers w/ turbo mufflers dumped at axle...15.70s and 20mpg
Mufflers removed, 3ft tubes on headers.....15.50s and 21mpg
TRW #274 cam, new chain, flex fan..........15.00s and 23mpg
Full duals from headers Dynomax mufflers...15.10a and 23mpg
K$N stub stack, softer secondary spring....14.90s and 22mpg
Magnum roller tip rockers, 1.52 ratio......14.80s and 24mpg
Magnum 1.6 rockers on exhaust side.........14.80s and 25mpg
PostPosted: Thu May 26, 2005 11:46 pm
Swap Specialist Mod
how does the milage keep going up? i think im missing something. when i was talking about the FI i was talkin about throttle body injection. like a stock truck or something. the TPI or tuned port injection is great but just a bit pricy for the parts. you can talk to Wicked Mayhem about the tpi though. he put it in his 305.
neil
PostPosted: Thu May 26, 2005 11:51 pm
the big problem with 305's basically is that they don't breathe well.. a good set of ported heads with increased valve size 1.84/1.60 would do wonders, throw on a good set of headers and a matched intake carb and youo should be doing alright in a light little truck. I've been readin up over on thirdgen.org on engine buildup and there's a lot of 305 info there. Some stuff would apply for yours... and the classifieds might helo also.
PostPosted: Thu May 26, 2005 11:56 pm
Swap Specialist Mod
hey can you put 4 inch bore heads on a 305. like some ported 2.05 1.64 heads. i know that the 305 has a 3.74 inch bore, so you might have a shelf in the chamber, but if you put some strong internals i the motor and with the big chambers you could put alot of boost to it. you would think so, eh?
neil
PostPosted: Fri May 27, 2005 12:05 am
for a budget builder the 1.84/1.60 is a good move. the crap heads won't flow enough to see the engine's potential but there are a few good stock cast iron heads designed for the little 305 that work good. if you want to throw money into it, i like the 335 stroker kit from powerhouse in bakersfield. minimal machine work and a 65-90 hp increase, some afr 185 heads ported, big crane cam, stock tpi with some 30 lb injectors, a little prom tuning and you'll be golden.
but i digress...
PostPosted: Fri May 27, 2005 9:33 pm
ok well ive been thinking about it. since it was free. im thinking of rebuilding it my self. also if i where to go full roller some alum heads will it help me in gas? or not reall? some light weight pistons and rods? stuff like that? cuz if i do do all these things it will be daily driven truck.
PostPosted: Fri May 27, 2005 9:48 pm
i personally think your money would be better spent elsewhere than on aluminum heads. for the cost of the aluminum heads you could get a good stock casting head and a tpi setup and perhaps even more. I'd check some of the third gen f-body sites along with other sites such as for the monte carlo body style. There's a lot of good info out there on getting some performance increases out of 305's. The big issue if you go TPI is the electrical side. wicked mayhem did a tpi on his truck and can perhaps provide some info on that side of things. if it were mine, i would do a stock bottom end, 061 or 416 head with bigger valves, an L98 cam edelbrock performer intake, and a good carb, set of headers, a msd ignition setup and a turbo 350 and you should be all set. decent performance, not too expensive and pretty reliable.. can't speak for the milage part but it should be fairly good considering the light load the motor will be pulling.
PostPosted: Sun May 29, 2005 10:36 pm
what do u guys think of this cam for my motor? http://www.cranecams.com/?show=browsePa ... e=camshaft or no good?
PostPosted: Sun May 29, 2005 11:38 pm
These are good 305 heads to use for increase compression(14022601...80-86...267V8 / 305 V8......1.72"/1.5" or 1.84"/1.5" valves, 53cc chambers)They are real common on the 267 Chevy V8 put in some Camaro's and Malibu's etc.These also wook good but have 58cc chambers 14014416...80-86...305..........1.84"/1.5" valves, 58cc chambers
The 601's or 416's can be fitted with 1.94/1.60 valves.It's a good idea to un-shroud the intake valves just alittle.These heads work better if ported.
The 2.02 intake valves will hit the block on the small bore of a 305.With flat top pistons the compression will be around 9 / 9.5 to 1.You can stroke the 305 on a bugget by:using a 400 crank turned down on the mains to fit the 305/350,use stock lenth 5.565 400 rods and use the any 305 piston(flat top,dish,dome).More commonly known as a short rod stroker.
Just my opinion, everyone has their own way.You can gather all the info and build it the way the best fits your needs.
Thanks
PostPosted: Sun May 29, 2005 11:43 pm
Hey Nelson, sorry I had to leave earlier... :lol:
That cam looks good, just watch your gearing. 4.56 or 4.10 gears might be a little low for driving down the highway. Use Richmond's gear calculator and try to figure it out to where 75-80 miles per hour would get you around 2700-3200 or so RPMs.
http://richmondgear.com/streetcalculators.html
I think blue meanie has 2.75:1 in his. With 26 inch tall tires, that works out to 2850 Rpms at 80mph. Perfect!
The stock 4.56 gears at 80mph would be about 4700 Rpms. That's a little high for my tastes.
Good luck. I'm no expert, but I hope it helps.
