It is currently Mon Jun 08, 2026 4:16 pm
 Post subject: clutch pedal
PostPosted: Thu May 12, 2005 11:44 am
ya, so i was driving home the other day and my clutch pedal fell off. I didn't get much of a chance to look at but where it pivots it just kinda snapped off. I seen like a 4 inch long 17 mm bolt. If i take this out will that assembly come off of there or is it going to be more complicated than that? I figured I would just take the one off my parts truck instead of trying to fix this one. Any help would be greatly appreciated.
Most people think of their skin as an ally. Makes me rethink having skin at all
PostPosted: Sun May 15, 2005 1:44 pm
Look through the old posts around here. I saw once that you could still buy a new steel piece that goes up under there to hold the pedal. I was able to mickey mouse mine but it won't work forever.
PostPosted: Sun May 15, 2005 2:59 pm
This is fairly common on 78 and newer trucks with the cable clutch. 77 and older pivot at a different point due to the hydro clutch master cylinder. I've yet to have any trouble with any of the older hydro clutch brackets. Here are a couple of old posts regarding this:
http://forums.luvtruck.com/viewtopic.php?t=6274
http://forums.luvtruck.com/viewtopic.php?t=3636
http://forums.luvtruck.com/viewtopic.php?t=2537
I was able to take the bracket out through the hole the gauges sit in. Once you have it out you'll need access to a welder to fix it up. I recommend adding some gusseting to strengthen it up. If yours is too far gone you could pull one from a junkyard truck. Just make sure you get one from the right vintage of truck. 72-77 are the same, and 78-80 are the same. If you want a new one, here are part numbers, if a GM or Isuzu dealer can still find them:
94022556 series 2-6 (1973-1977)
94027039 series 8-10 (1978-1980)
A new bracket for series 8-10 is still going to fail eventually. I'd weld extra support on a brand new one if it was going in my truck.
 Post subject: bracket
PostPosted: Sun May 15, 2005 4:55 pm
Buy a new bracket thru your Chevy dealer. The part number is in one of my posts here.
PostPosted: Mon May 16, 2005 11:22 am
Thanks for all your help, I got it out through the gauge hole and got it welded up. It wasn't too bad, i threw some more metal on there to make it stronger. I hope to get it back in this afternoon.
Again, thank you
