It is currently Thu Feb 19, 2026 6:31 am
 Post subject: New Bushings??
PostPosted: Sun May 08, 2005 3:08 pm
has anyone replaced the bushings in the sway bars or controlm arms??? and where did u get them
cause mine arem all ate up
PostPosted: Sun May 08, 2005 3:21 pm
Some of them are available through partsamerica.com
Others may have to come from Isuzu. You might try to cross reference an 83-86 Trooper or Pickup. The steering linkage is identical on an 86 Trooper.
I still have to compare, but I may also have a few spare bushings. Check back in a couple months. (When my project's front-end should be together.)
-DK
PostPosted: Sun May 08, 2005 6:45 pm
NAPA can order the control arm assy's (rod and bushings) plus pretty much everything else you need.
Upper control arm shaft assy NCP2803595 $51.49 ea.
Upper ball joint assy NCP2601191 $39.99 ea.
Lower ball joint assy NCP2601293 $36.99 ea.
Sway bar repair kit NCP2651208 $ 8.49 ea.
Strut rod bushings NCP2749073 $26.49 ea.
Idler arm pivot bushing BA1013863 $15.49 ea.
I'll be ordering tie rod ends in the near future. I'll post the P/N's and prices for you.
