It is currently Wed Mar 25, 2026 1:53 am
 Post subject: Rear end width
PostPosted: Sat Nov 23, 2002 11:32 pm
what is the width on a s10 rearend, and will it handle a 406 with about a 150 plate system with a spool in it?
PostPosted: Sun Nov 24, 2002 12:08 am
There are several posts that are on here that cover the s10 rear ends....use the search button.
I wouldn't get to crazy with the motor if I was running an s10 rear.
Just spend your money once and get a 9" Ford and narrow it.
It will handle anything that you can throw at it.
Giles5
PostPosted: Sun Nov 24, 2002 6:37 am
NO it WILL NOT hold up!!! I had one in my truck and took it to the local track for some fun and broke a axle on the very first pass.With the C-clip design of the Chevy there is nothing to hold the axle in to the housing.I do not have a ground stomping big block in my truck I am building a driver and since the SB400 has a bunch of tourqe and then add the nitrous I feel it would be trouble just waiting to show up.
After my little trip to the strip i came home just glad that I was there early,running a solo run and no one got hurt.I feel lucky because I ended up in the wrong lane pointing back at the christmas tree with the axle and wheel rolling past me .However you may not be this lucky.
I have put a 9" in my truck and also added a 100-175 hp nitrous because at least my axles won't be flying out when I can get back to the strip.
If you do use it at least buy C-clip eliminators but in my opinion any money spent on a S-10 rearend would be money spent twice because you will probably end up with a broken rearend and going to a 9"anyway!
stripped and just a memory!
PostPosted: Sun Nov 24, 2002 7:54 pm
well said ratnluv
 Post subject: hit me up
PostPosted: Thu Nov 28, 2002 9:00 am
Japanese Redneck
Rustobust. I have 2 narrowed 9" housings (spares) for a my LUV truck. and just your luck... I am in San Diego. I've seen you post on the SDMS board there. If you are interested, send me an email at chevymetal5@hotmail.com.
Rico
PostPosted: Fri Jan 24, 2003 5:36 am
A 2WD S-10 rearend is 48" backing plate to backing plate. A 4WD S-10 is 52" wide.
There's 2 different ring gear sizes for the S-10. '91 and up use basically the same rearend as an 80's Camaro or Firebird but S-10's are narrower. '90 and down are a smaller ring gear and weaker yet.
I have a V8 S-10 Blazer with a stock non-posi rear. It's powered by a 375HP/327 with a close ratio Muncie 4 speed and a 12" clutch. I have 9" wide rear rims wth 325/50/15 Goodrich TA tires. I've sidestepped the clutch at 6000 RPM a few times and amazingly it's still together. 8O 8O
I do already have a narrow Dana to install in it, as I don't trust that puney little thing in there now.
I'd listen to RATNLUV about the Chevy C-clip thing. It's not pretty when you see your axle and tire pass you, cuz you know in about 2 seconds you're going to be in for one hairy ass ride.
Go for the Ford 9". Then you'll only have to install it once.
When everthing goes wrong....
What's right is what's left.
PostPosted: Fri Jan 24, 2003 7:31 am
I learned about the c-clip style rear ends a long time ago.
A buddy that had a faaaaaast monza had holes all in his quarter panel from the axle breaking, coming out then stabbing in the Q panel......
he just kept putting axles back in and breaking them.....doesn't show how smart he was, but that car was fast.
03Cobra
PostPosted: Fri Jan 24, 2003 3:46 pm
i have heard from an annonomous source that a 9' out of an older ford bronco square body style has about the same width as the chevy luv if anyone has any info on this it would be greatly appreciated
PostPosted: Sat Jan 25, 2003 2:57 am
I looked at a 68-72? Bronco rear for my S-10 and if I remember right it was 50" or 51" backing plate to backing plate. About 2" or 3" wider than a 2WD S-10. The guy wanted $250, it had 3.50 gears and broken short-side axle. Was probably still a good deal, but wider than I wanted
I don't know what width the stock Luv is, but aren't they the same as S-10? Guess I could measure my Luv :oops:
PostPosted: Sat Jan 25, 2003 10:45 pm
I WAS AT THE BONE YARD THE OTHER DAY AND MEASURED A 4X4 LUV REAR END AND THE LENGTH WAS RIGHT AT 47.5" BACKING PLATE TO BACKING PLATE.
I HOPE THIS HELPS.
GILES5
 Post subject: s-10 diff for LUV
PostPosted: Wed Feb 19, 2003 12:45 am
I use to run a S-10 for quite a while. I put a Auburn Pro diff. and Richmond gears. C-clip eleminators should be used, I think that atleast 4-500 hp would be ok. Maby a Summit billet diff cover with the preload bolts would help.
