It is currently Mon Jun 08, 2026 10:13 am
 Post subject: valve cover gasket
PostPosted: Tue Apr 05, 2005 9:28 pm
What is gonna work better? 1/8" cork or high temp rtv? The caulking on mine started coming off like boogers.Anybody have any feedback one way or the other?
Dr. Frankenstein
PostPosted: Wed Apr 06, 2005 2:12 pm
Banishment Pending
try useing a cork gasket, with a thin layer of rtv silicone on that, it should work pretty good, just don't overtighten those valve cover bolts.
 Post subject: gasket
PostPosted: Thu Apr 07, 2005 10:32 pm
After I got the gasket installed on the valve cover, I run a small bead of Permagasket #2 on the head side of the gasket just before I install the valve cover on the head. This seals up and leaves the gasket to act like a reverse coffer dam, keeping the engine oil from seeping out underneath the gasket.
