It is currently Wed Jun 17, 2026 2:57 am
 Post subject: Front Disc for 75 luv
PostPosted: Tue Mar 29, 2005 5:27 pm
I found a set of disc brakes at a local junk yard that are usable. The thing im wonderingis.. what all do I need for the conversion? Calipers and Rotors? or do I also need the spindle and stuff. And also will any year work for what I'm doing? Thank you for the help
PostPosted: Thu Mar 31, 2005 10:34 am
You need to pull everything off including the spindles. Don't bother with the brake lines though, just get a new set. This is a really easy swap btw. Pretty straight forward. Seems like someone posted a detailed explanation of this swap sometime back, could try a search...
Resident lurker
PostPosted: Thu Mar 31, 2005 11:11 am
http://www.luvtruck.com/PDF/LUVDiscBrakes.pdf
here's the link to the article on the site...
