It is currently Mon May 25, 2026 9:46 pm
 Post subject: 4x4 gear ratio
PostPosted: Fri Mar 18, 2005 6:57 pm
Does anyone know what ratio is in a 1980 luv 4x4? Thanks for your help.
PostPosted: Fri Mar 18, 2005 7:24 pm
4:10 according to the factory info I have
PostPosted: Sat Mar 19, 2005 9:22 pm
Thanks for the info!
PostPosted: Tue Mar 22, 2005 2:50 pm
Banishment Pending
that depends though, according to my manual the autos had 4.10, but there where no auto 4x4s made in '80, so that means you have 4.56
PostPosted: Wed Mar 23, 2005 5:04 pm
Auto 2wd's AND 4X4's had 4.10
Manual 2wd had 4.56
PostPosted: Wed Mar 23, 2005 10:21 pm
As far as I know, all 4x4s had 4.10
You can check it as follows (This works best with a friend to help):
Put the truck in nuetral and jack up 1 wheel. Spin the wheel 20 times while watching the driveshaft. If the driveshaft spins 41 times, it's a 4.10 If the driveshaft spins 45.6 times, it's a 4.56 Basically, dividing the driveshaft spins by 10 gives the ratio. This will work on any open differential.
You went there in that?!?!
PostPosted: Mon Mar 28, 2005 5:55 pm
Banishment Pending
I'm sorry to say but i think your wrong, according to both of my manuals the 4x4's have 4.56's, that and i have also checked this because if you look at isuzu's later products(Trooper) you will find that most of them had 4.56(they where all 4x4 so that dosen't matter) the exceptions are thoose that had the wide tire package(4.77) and the autos(4.10, and or 4.30), and further more I have personally tested my truck which happends to be a '80 4x4, and it has 4.56 gears so i'm sorry to say but i believe your wrong.
PostPosted: Mon Mar 28, 2005 9:17 pm
My 79 factory shop manual says the front diff has 4.10 gears only while the rear can have 4.10 or some other ratio (can't recall off the top of my head) I haven't tested any of my trucks but I'd go with the factory manual instead a haynes or Chiltons book.
Just an FYI, my series 5 factory shop book has yet another ratio listed. I believe through the years several ratios were used, something to keep in mind when looking for a replacement. Especially if you have a 4x4, things break quick when the front and rear ratio don't match and you lock those hubs in. :wink: That might also explain an 80 with 4.56 gears in it too. They did change several things for 1980 including a minor trans change and a larger clutch on the 4x models so a different ratio wouldn't be a shocker.
PostPosted: Tue Mar 29, 2005 12:37 pm
Banishment Pending
i think my info is crediable, I got the same ratio for the 4x4 from my series 10 shop manual and the haynes manual too, so I'm going to lean to the fact that '80 4x4s have 4.56 gearing front and back.
PostPosted: Tue Mar 29, 2005 2:57 pm
This sounds like a good reason for me to complete my factory shop manual collection. I've got a series 5 and a series 9, so that only leaves about 9 more. :)
PostPosted: Wed Mar 30, 2005 10:37 am
Banishment Pending
yup i guess this would be a good time to upgrade a little, and expand the luvitica collection
PostPosted: Thu Mar 31, 2005 12:52 am
I just double-checked my 79 4x4, using the procedure above, and it's 4.10. Of course, that's a sample of 1.
PostPosted: Thu Mar 31, 2005 12:30 pm
I've got an 80 and 3 79s, next time I have a rear wheel off the ground on any of them I'll do a check. My 80 has a lot of mismatched parts though, so I'm not going to trust that it will represent all 80 trucks.
I suppose I should check the 76s I have and the 77s too, I have one 77 rear that came in an auto tranny truck.
PostPosted: Fri Apr 01, 2005 11:18 pm
i bought my 79 4x4 from a guy who swore up and down it had 4.56s. I havent tore it down but i know my 80 has 4.10s and my 78 2wd has 4.56s.
 Post subject: ratio
PostPosted: Wed Apr 13, 2005 11:42 am
I have an 80 4x4 with factory AC, when replacing the bearings in the rear end the ring and pinion teeth count revealed a 4:10 ratio.
1980 4X4 LUV
PostPosted: Wed Apr 13, 2005 11:48 am
Ok guys old school trick.
Jack up one side of the rearend off the ground. Put a mark on a rear tire and have someone watch the tire. Mark the drive shaft too. Turn the drive shaft and count the number of rotations of the drive shaft to make on full roataion of the tire.
A little over 4 turns would = 4.10
A little over 4 1/2 turns would = 4.56
3 3/4 turns = 3.73
and so forth.
HTH
Richard
PostPosted: Thu Apr 14, 2005 1:06 pm
When one wheel's stopped, the other wheel turns twice as fast. Therefore, for 1 wheel rotation, a 4.10 would give you 2.05 driveshaft rotations, not 4.1.
For a 4.10:
1xWheel = 2.05xDriveshaft
2xWheel = 4.10xDriveshaft
20xWheel = 41xDriveshaft
Which fits the procedure I described above. Note that I used 20 rotations because it's sometimes hard to distinguish partial rotations. Using the procedure I described above, for 20 wheel rotations:
3.73 = 37.3 Driveshaft rotations
4.10 = 41 Driveshaft rotations
4.56 = 45.6 Driveshaft rotations
PostPosted: Fri Apr 15, 2005 9:43 pm
My 80 4x4 has 4.10s in it. but I have a spare front end and its 4.56s
PostPosted: Thu Apr 21, 2005 3:58 pm
Well this thread got me thinking so I went out and did the old spin the wheel game. 81 4x4 Man
Mine was not a 4.10 or a 4.56 mine is 5.2X it was slightly more than 52 turns on the shaft. Now I know that some custom work was done on this truck a farmer used it to pull stuff around his farm. So maybe he changed it. The thing is where did he find the parts?
I always new something was fishy when the truck top speed and I mean top is 62 MPH
Funny $hit
Rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Thu Apr 21, 2005 7:12 pm
I dunno. Maybe it's not a Luv differential. A picture would be really cool. Maybe someone could identify it.
