It is currently Wed May 13, 2026 3:03 pm
 Post subject: What happened to 1 and 4
PostPosted: Wed Mar 23, 2005 3:49 am
With the motor running, I pull off the #1 and #4 plug wire. There is no change in rpm. I get a spark from both wires, but for some reason BOTH #1 and #4 cylinders are not fireing. What could have caused this, and what can I do to fix the problem???
PostPosted: Wed Mar 23, 2005 5:57 am
well with no rpm change, that kinda scares me. Try runnin up the rpm's a little and see wut happens. How does the truck run. Maybe I missed something. I am guessing, right at the moment it is running like shit? If for some reason you have no compression in the 1-4 cylinders then its time for a new motor. Good luck, and keep us posted!
PostPosted: Wed Mar 23, 2005 9:05 am
It could be something as simple as dead or weak plugs. Run the engine, then pull the plugs and see if they are wet.
PostPosted: Wed Mar 23, 2005 12:21 pm
You might check that the plug wires are all on in the right order. If #1 and #4 got switched that could explain your whole problem.
PostPosted: Wed Mar 23, 2005 1:27 pm
Mr. Cylon is right. I goofed up the firing order like that, and swapped them back and whapow!
She peels out now!
PostPosted: Wed Mar 23, 2005 1:37 pm
Cylon.. now that speaks volumes... i had this problem with mine also and it was the cap... the little contacts in it where the plug wires went were gooned up...
PostPosted: Wed Mar 23, 2005 2:17 pm
I put a new dist and rotor on it, and finally found that stupid thingie and come to find out, I had the 1 and four backards.
But with the new ignition system, it runs a helluva lot better.
