It is currently Mon May 25, 2026 11:19 pm
PostPosted: Tue Mar 08, 2005 12:53 am
ok
i know there are alot of luvs in ca that have v6 & v8 s
question is ???????
IF i put all the smog equipment from say a 82 camaro on the p/u does that make it smog legal?
i know i should call dmv but i want to see if i will seem like a dumb S.
it makes sense right?
i have been told when swapping powerplants you MUST go up a year or two
any answers out there? :?:
PostPosted: Tue Mar 08, 2005 1:24 am
I had an 81 nissan 4x4 w/ a 327 in it, and I lived in Cali at the time. I had to take it to the smog master, and the requirements for the motor which was a 62-67 327 was a stock breather, heat riser from the manifold to the breather, and a pvc valve. So I put all that on, and got it smogged then yanked it all back off :twisted: So basically you will have to have what ever the year of motor requires to be smog legal, then do what you will afterwards. GOOD LUCK!!!!!
PostPosted: Tue Mar 08, 2005 8:48 am
This should give you an idea on the rules here in CA. It's not as horrendous as it seems, but having said that... it can be a pain in the butt.
http://www.jagsthatrun.com/Pages/Chevrolet_S-10_V-8_Smog.html
 Post subject: thanks for the info
PostPosted: Tue Mar 08, 2005 11:24 am
:o WOW i'm totally stoked!
thanks you guys that is exactly what i hoped for
maybe in about 9-10 years well be out of ca but in the mean time my son needs a cool ride when he goes to high school ( he's 7 so i got time ) i had a 79 pinto with 289ci when he was born plus "car" is in his blood as in mine i get it from my pop , the dude cant read or write but he knows his cars! and he can clean a mean toilet ( he's a custodian @ a major junior college in walnut ca ) since 1966 hes had that job.
THANKS DAD! :)
PostPosted: Tue Mar 08, 2005 12:27 pm
Japanese Redneck
I have a BAR label like the one pictured above. it says 1964 327 with an X in the PCV box. so basically what that means is I can put any small block I want in it as long as it resembles a 327 with a PCV valve (cant fool the BAR with a big block). They dont give out labels like that anymore. only for engines from a car that is later model than the recipient and it has to have all the factory smog equipment on it.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Mar 08, 2005 12:38 pm
I contacted the referee station about a year ago when I was still going with a 350 in my LUV. The guy I talked to said it's really not that bad to get the car done. Just make sure you select the right engine (least amount of smog equipment like from a Silverado truck), that you install all of it correctly, and when you take it in to the referee, have the information he needs (i.e. engine year/size/codes, where each smog item is located) and it goes smoothly. Didn't sound that terrible actually talking to the guy that gives you the ok.
PostPosted: Tue Mar 08, 2005 12:42 pm
Japanese Redneck
find a silverado that has no air pump on it. the rest is not too bad
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Mar 08, 2005 1:04 pm
that's it exactly.. you just have to make sure it's not one of the "heavy duty" truck engines and you'll be all set
 Post subject: right on
PostPosted: Tue Mar 08, 2005 1:09 pm
i called the salvage yard close to me and they want only 113.00 for the motor and 89.00 for any trans SWEET
i have a buddy in vegas that will give me a master rebuild kit for 50.00
sorry no deals me only thats what he said :cry:
but im in no big hurry i want it done but i rushed on a ford 360 and it blew up so no more rushing on builds, im also in the process of buying a house so that is were the money heads eventhough i got 125% financing still gotta pay the day workers a good wage + beer to help me move all my crap.
PostPosted: Tue Mar 08, 2005 1:11 pm
awesome prices on the engine/trans... can't get things up here for that low.
 Post subject: sweet prices
PostPosted: Tue Mar 08, 2005 2:54 pm
yeah makes it worth the drive huh?
im going on the 1/2 price day and get it even cheaper than that!!
PostPosted: Tue Mar 08, 2005 5:20 pm
so what place is this??? I am down that way every month or two and it sounds worth checking out...
 Post subject: yards in the I.E.
PostPosted: Wed Mar 09, 2005 1:08 am
take I-5 or I-15 south to I-10 = from 15 go west from 5 go east
in ontario get off on milliken go south ( away from the big mountains )
past jurupa ave keep going south it will be on the left just look hard
in monrovia exit I-10 on peck road go north towards mountains it is a little driveway on left all the way in the back
check the recycler ads if you got them up there to find out the days or go too http://www.pickapart.org i think thats it
ecology is in san bernardino off of waterman call 411 never been there seen it from street
and theres one in adelanto up in the desert off I-15
