It is currently Wed Mar 25, 2026 9:51 pm
PostPosted: Sat Mar 05, 2005 10:55 pm
:cry: ok,, we have just bought our 1980 chevy luv automatic,
we were looking for a flexplate (flywheel) found that (155$ later)
but now haveing more problems..... we might have a short in our
igintion the unaversal one stinks cause all the wires dont line up.
we are really confused cause we looked at this sites diagram
and it looks greek to us. there are 5 wires. :: ig, acc, am, st, r.
what do they all mean???????????????????????????????????????
the unaversal one only has :: st, acc, bat, ign.... now where dose the
am go and what in the world is am????
after all that we drained the battery over this! :x it kinda stinks!
but anywho... we also have a timning problem i think,,,, when the
engine turns over it rocks reall hard and it want to die, it sputters and
shakes and dies a few times....................... we are sooo new at this,,,
we need step by step directions/////// we just need to get this truck running befor we can have fun with extras. if you can help ...... thank you
PostPosted: Sat Mar 05, 2005 11:29 pm
the dieing sounds like timming to me. beyond that im lost. am..hmm...maybe after market.....i don't know...just a guess
good luck
anthony
PostPosted: Sun Mar 06, 2005 1:19 am
well as far as the truck running goes it sounds like the timing is too far advanced. Loosen up the Dist and just move it around untill it starts sounding better. Im perty shure that counter clockwise will retard the timing which is what i would start whith. As far as the wiring goes i dont know anything about the universal kits but i do know that the ignitions off of the 81-82 LUVs is a VARY easy swap and i wrote a tech article on that swap (i did it on my 80 4x4).
As far as the wiring abreiviations go, ig is ignition or the switched power, acc is accsesory whith will just run the radio and heater motor but nothing else, am im drawing a blank on that one, st is start whith will give power to the starter and then r is just run which just feeds power to all the systems. I hope that helps some.
 Post subject: wow thats better
PostPosted: Sun Mar 06, 2005 5:18 pm
ok my husband ran a new power wire and boooooooooooooom thats is now we just have the carb to replace dont know how much they will cost...
new or re-built thanks for all your input :D
PostPosted: Mon Mar 07, 2005 7:41 pm
go with a weber DEFINATELY, my dad and a guy he works with have re-built the hitachi carb that's stock before and even after the re-build it still ran like crap... they're far too complex to just simply re-build really... so go with the weber you'll be happy you did, and just ask around, most anyone on here will tell you to go with a weber
PostPosted: Mon Mar 07, 2005 9:19 pm
cool...... now how much is a weber and can i just go to napa and get one??
we also have lots to do to it still i will have pictures soon... thanks all
PostPosted: Mon Mar 07, 2005 9:26 pm
look for an import performance shop. Ones that specialise in older VWs and Audis things of that nature are garenteed to have one on the books. What you looking for is the 32/36 pregresive 2barrel. Theres a kit that makes it perty much bolt on. Its a great carb and vary easy to work on, your probly looking at about $400 for the full kit. I would do this, the Hitachis dont rebuild well and are garbage in comparison.
PostPosted: Wed Mar 09, 2005 10:18 pm
Luvtruck.com Wookie
MEPR wrote:
I would do this,your probly looking at about $400 for the full kit..
do yourself a favor and look on e-bay.....i scored my weber for $30.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Mar 10, 2005 6:38 pm
thats about what i have seen brand new kits going for. Should have thought to sugest e-bay :oops: :lol:
PostPosted: Fri Mar 11, 2005 7:59 pm
ok i have a nother question for you all....
our battery keeps dieing,,, i think we might have a short in one of the main wires what do you all think????? and how can you fix something like that?
