It is currently Fri Mar 27, 2026 6:06 pm
 Post subject: choke
PostPosted: Tue Mar 01, 2005 5:41 pm
my carby is set up for an auto choke but the luv is set up for a manual one, anyone know how to wire up the auto choke, or connect the manual choke cable to the auto setup?
PostPosted: Tue Mar 01, 2005 10:36 pm
It looks like you should be able to just hook it to the fuel cut solenoid wiring that should already be there even on a truck setup for manual choke. (72-74) It will be the black/yellow wire on the connector that did/does go to your carb. (On the firewall right behind the carb) The auto choke should have 12v power when the motor is running optimally, or with the key on if nothing else. If you hook a test light or multimeter to that BY wire it should have power only when the motor is running I believe.
Its been a long while since I've dealt with a pre-76 style motor, and never have had to deal with one not wired for an auto choke. That should be the closest wire to what you want. The alternative would be to hook to the coil's power source. Trace off the + side of the coil, you should find two wires that lead to it. One goes straight to it out of the harness, the other comes from a little box that is the resistor. Hook the choke onto the side of the resistor not connected to the coil and you'd have a 12v source hot only when the motor is running.
The choke just needs power to pull itself off after the right amount of time. Power it from the key if you have to, just like you would a radio or something. It will otherwise just tend to stay on, which you probably already are dealing with.
Hopefully that Aussie truck of yours isn't too different in the wiring scheme and all this should work. ;)
PostPosted: Wed Mar 02, 2005 11:18 pm
nah all the wiring is the same, judging from the manuals i have gotten from the US. how does an auto choke work, i know of the 12v black yellow wire your talking about, is that all it needs, 12v?
PostPosted: Thu Mar 03, 2005 12:24 am
Yeah just needs 12v, optimally with the motor running. The power heats up the spring in the choke and makes it slowly back off as the motor heats up.
PostPosted: Thu Mar 03, 2005 7:50 pm
how do you set it? i think it is all the way open atm
PostPosted: Thu Mar 03, 2005 8:45 pm
The round cover over the spring has an index mark on the side that lines up with a similiar mark on the metal housing. When putting the two together, spin the cover around so the finger inside engages the end of spring and tighten the cover screws when the marks are aligned. In cold weather, the choke should be open about 1/8th inch after pumping the gas pedal once.
Users browsing this forum: No registered users and 56 guests
