It is currently Mon Jun 08, 2026 5:27 am
 Post subject: undercoating
PostPosted: Mon Feb 21, 2005 10:33 pm
ive never undercoated before. and i need to know if it is just a can of paint or a sertian thing? if any one know please help me thanx
PostPosted: Tue Feb 22, 2005 2:15 am
You can buy spray cans of undercoating. I have used it before, and it works pretty good.
PostPosted: Tue Feb 22, 2005 11:46 am
the undercoating stuff is great, just make shure you tape off/cover up the areas you don't want undercoated (tranny, underside of engine). oh and make shre to wera gogggles and something over your mouth (those little paper particle dust catcher things) when you do decide to crawl uder your truck to undercoat it. That stuff taste like crap
If everybody grows up with high self-esteem, who is going to dance in our strip clubs?
What's going to happen to our porno industry?
These women don't just grown on trees.
PostPosted: Tue Feb 22, 2005 7:27 pm
Yeah, be sure to cover up your panels w/ some newspaper and painter's tape (or duct tape... it has more adhesive) and mask all you don't want it on, speacially your driveshaft... i'm not sure but it may throw it off balance.
I undercoated the front underside of my LUV and the rear wheel wells with a little under the floor mats (sprayed it over the bondo-filled holes in the floorboard)
So does carburator cleaner but that's another story....
PostPosted: Tue Feb 22, 2005 9:44 pm
I ruined a good ski jacket back in 1983 undercoating my 1/2 ton Chevy. It worked well, I put the truck up on a lift at my friends gas station. That stuff splattered a lot but it turned out o.k.
PostPosted: Tue Feb 22, 2005 10:45 pm
lol every one im not undercouting the under carriage tho. im going to undercoat the inside cab so it wont rust. i think that will be a good i dea right? is there a sertian undercoat i should get and ill make surew i wont eat the stuff lol.....thanx this sitew is very helpfull
PostPosted: Tue Feb 22, 2005 11:54 pm
The under coating isnt smooth. It has a texture to it. You might think twice about it, unless you want the inside of your cab to have that look, plus I dont think you could paint over the under coating, so the inside of your cab will be a sorta brown/black color. :?
PostPosted: Wed Feb 23, 2005 6:14 pm
well my uncle made that suggestion because i'm putting the carpet in ti any ways so i thought ill ask you guys for a little advise for a sertian brand or something well thanks tho
PostPosted: Wed Feb 23, 2005 6:47 pm
i was thinkin of putting bed liner in mine. i even found a brand that has a couple diff colors. i think it was Dura-Bak? or something to that effect. ill look right quick and get back to you.
PostPosted: Wed Feb 23, 2005 6:51 pm
here is the link.
http://www.nonslipcoating.com/
these guys covered a whole jeep with this stuff. it is a rather industrial thing. it is used on oil rigs in the ocean cuz it is a no-slip formula. it has MANY uses. not too expensive either. it got good reviews against lava-liner. I might go for it one of these days in my luv.
PostPosted: Wed Feb 23, 2005 9:07 pm
I just realized you were talking about in the cab. My buddy sprayed his fire wall and fender wells on his 65 chevelle with what we call speckle paint. It was black with white splattered in it. It was kind of the thing to use before rhino lining and such. It has a rough texture and is pretty durable.
PostPosted: Thu Feb 24, 2005 11:43 am
That speckle paint is quite durable. It used to be sprayed on the inside of aluminum boats. Don't know if it still is. Anyway, my little fishing boat has it inside, and I bought the boat 20 years ago and the paint is still protecting. Undercoating in spray cans comes in 2 configurations: Hard drying and soft drying. I've used the hard drying on the inside of fenders and floor boards and it works very well. Plus it protects battery wells and holders from corrosion.
 Post subject: hope this helps
PostPosted: Tue Mar 08, 2005 10:36 pm
I just bought some Bed liner the other day at pep boys I think it was 10 bucks I plan on doing the same thing Painting the floor pans to help prevent any further damage. hope this helps
