It is currently Mon May 25, 2026 10:41 pm
PostPosted: Mon Feb 21, 2005 9:25 pm
what is that fells in the rearend. :roll:
PostPosted: Tue Feb 22, 2005 6:13 am
if you have a V8, just hope you don't hook up.
I broke the rear in mine back in 94 on new years day. I did a smokey burnout and hit second gear. It hooked up, broke the rear, tranny (5 speed), and U-joint. That was with the buick V6 in it.
If you have the 4 banger.....I don't see it giving you a problem.
03Cobra
PostPosted: Wed Feb 23, 2005 11:20 pm
let me know more .. the u-joint is what gave out . on yours ? cool
thank you .
PostPosted: Thu Feb 24, 2005 4:57 pm
the v8 if that is what you have should work with that rearend thats what i plan on doing with mine any way. if i do blow the rearend up than ill just go get another one from a recking yard or a s10 rearend can hold a little more horses
PostPosted: Thu Feb 24, 2005 6:26 pm
Yeah, if V8, and the rear end is in good shape (low miles), it should be able to take about 260 hp. A wore out rear end might have trouble with anything more then stock hp....
There is numerous guys running mild V8's out there with stock rears.
PostPosted: Sat Mar 05, 2005 9:43 pm
Keep in mind guys that it's torque, not horsepower, that breaks things. With a taller set of gears, you should be fairly safe with a V8 considering that torque is multiplied by gearing, horsepower is not. Just a note to think about
 Post subject: rearends
PostPosted: Sun Mar 06, 2005 5:48 am
ask polished steel........he is running a stock rear with a sbc and nos.
 Post subject: luv rearend
PostPosted: Sun Mar 06, 2005 9:24 pm
i put a 355 in mine and ran 11.24 in the 1/4 mile @ 119mph. with 10''slicks. i took the pumpin out and welded the spider gears together making a locker or spool. ran it a least 1 1/2 seasons at the drags. now went to a 9'' narowd ford cuz i dropped in a 468.....
 Post subject: cool
PostPosted: Sun Mar 06, 2005 9:49 pm
welcome to the site........
PostPosted: Mon Mar 07, 2005 3:58 pm
cool like the info keep it comeing . :smt102
