It is currently Thu Mar 26, 2026 10:36 pm
 Post subject: 1977 custom deluxe
PostPosted: Sun Feb 13, 2005 11:18 am
Alright guys need some help just got a 1977 custom deluxe.....
It has small 350 with t359 automatic trans....
I need to adjust the valves they are clattering like they are loose......so want to adjust them...any help would be appreciated thanks
PostPosted: Sun Feb 13, 2005 3:35 pm
Is it a chevy nova custom or does it have a GM motor. If it is I have the adjustments for it I just have to get the book from my mother in laws house.
PostPosted: Mon Feb 14, 2005 12:03 pm
I believe what he has is a plane jane pick up truck. A Silverado Scottsdale or what ever would have more creature comforts. Kind of a full size non Mikado.
PostPosted: Tue Feb 15, 2005 8:45 am
It says it is a 77 chevy custom deluxe...with a 350 small block...on the door panel....It also has heavy duty suspension im guessing for hauling
PostPosted: Tue Feb 15, 2005 11:38 am
Luvtruck.com Wookie
i got some bad news for ya......i don't think you have adjustable valves....unless that's not the stock motor.
my 78 was all hydraulic.... pull the covers off and look.....tapping in the top end of a hydro lifted engine usualy means that there.s not enough oil pressure getting to the lifters or that the lifters are worn to the point that they won't adjust with oil pressure......
try running an engine flush(oil).......sometimes there's crap in the oil cavities that reduce pressure to the lifters...... if that doesn't help try taking the lifters out and cleaning them.but don't forget to fill them back up before you re-install them.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Feb 17, 2005 10:43 pm
alright thanks....when the engine is cold according to oil pressure sensor guage its getting 60 lbs when engine is warm is getting about 15lbs at idle.....but thinking the cavities could be plugged
Will try it thanks all
PostPosted: Sat Feb 19, 2005 10:01 pm
Well i put some sludge remover in it and cleaned oil cavities and quiten down a bit but still having same problem...also took some of the lifters out and they dont have any wear marks on them to give me the thought that they would be bad but dont know that much about hydraulic lifters...any thoughts???? 8O
PostPosted: Sun Feb 20, 2005 12:25 am
Take a pushrod and push down on the lifter and see if the plunger moves up and down in the lifter, I had the same problem and my hydraulic lifters they turned into solid lifters and did not move at all. Just a thought .
