It is currently Mon May 25, 2026 7:23 am
 Post subject: 350 swap
PostPosted: Mon Jan 31, 2005 1:42 pm
i need engine mounts for a 350 in a 1980 luv 2wd
PostPosted: Tue Feb 01, 2005 2:17 am
You can order them from summit, or somebody here might sale you some.
PostPosted: Thu Feb 03, 2005 8:16 pm
LUVTruck.com's Cornholio
Yeah you could make some motor mounts like mine. They were easy to make too. No cutting or welding on the frame. Bolts right in with the stock mounts. Image
 Post subject: Aussie needs help.
PostPosted: Fri Mar 11, 2005 5:08 pm
Dude who is summit.
I got a price here in aus for the hooker extractors alone was 3000 bucks aus so 2200 your money i spose.
How much do you guys pay. I will need engine mount kit and header/exhaust kit for my 74.
And do you guys by chance know where I might get some disc brakes for the front of my 74.
Cheers Fellas
craig.wilson@joewhitemaltings.com.au
PostPosted: Fri Mar 11, 2005 10:27 pm
Here you go...
http://store.summitracing.com/default.a ... &x=13&y=10
Click on the link and it should show the motor mount and trans mount kits and the header assy.
As for the disk brake assy, find a later year truck and retrofit all the parts to your spindles and master cylinder too if your truck has the old single reservoir.
Users browsing this forum: Bing [Bot] and 22 guests
