It is currently Wed Jun 17, 2026 2:04 am
 Post subject: jeep stuff
PostPosted: Thu Jan 20, 2005 10:32 pm
ok well the jeep is almost done getting body work and painted
well im depending on buying this remanufactured engine from up north in mulino oregon a 4.2 liter jeep motor for $1150 and they install it which isnt too bad with 5 yr 50,000 mile warranty
i forget the name of the place but its in the nickle ads of oregon
does anyone know about them their work :?:
or else i might rebuild which i realistically would cost alot more than that
cause the 4.2 in it already has about 180,000 miles so i cant probably jus re ring it, although it runs just the stupid carter carb and vacuum leaks
i might rebuild it cause it'd be nice with a 4.0 l head and a 570 cfm street avenger carb and a good cam intake headers for dual exhaust
you can get 420 ft lbs out of the 4.2 which is cool but more money
then i also have to lift it spring over probably then a body lift and shackles
that should give me about 5-7 inches of lift
i'm excited about the jeep
then i will continue the 2 wd luv 383 stroker project
