It is currently Mon Jun 08, 2026 3:13 am
 Post subject: some questions again
PostPosted: Sun Jan 16, 2005 5:44 pm
well im back with some questions
my truck is really running poor
the max speed i can get out of the luv is 65-70 mph on freeway at around 3200-3400 rpm i believe
which i have installed a header, flowmaster with kinda large pipe 2 1/2 exhaust which was bad idea
i have the 32/36 weber on it and a fawcet fuel pump so i got some performance parts on it
i have it timed @ 6 degrees
no vacuum leaks around the carb base and hoses are plugged off
no egr valve either i covered it up
and also is it hesistates when i give it gas then it will pick up slowly and it gets only like 16 mpg on freeway so i think somthings not good
i have looked at other post but couldnt find anything with a positive answer
i have tried to get my dad to help but hes busy
any help would be awesome its my daily driver and scrapper too
i can take pictures of parts if needed
PostPosted: Mon Jan 17, 2005 12:02 am
How old is the carb. It may need a rebuild. If it has ever even once back fired up through the carb, it probably blew out the power valve in the carb. A broken power valve will make it hesitate when you first give it gas.
PostPosted: Mon Jan 17, 2005 1:29 am
its about a year old and yes has backfired a couple times through the carb when i was timing the truck and replacing plug wires i got the 1 and the 4 mixed up oops hmm interesting thanks rondog
PostPosted: Tue Jan 18, 2005 9:22 pm
ok luckily i had another weber carb on my other luv to grab off put it on the truck tonight no rough idle like my other truck did but right when i pulled off the weber on it before i had that blue silicone all like jelly out the gaskets about ready to fall in the intake
my dads friend who i shouldnt of listened to said he put it on his weber gaskets when he had a problem with air coming through the spacers
i cleaned it up that probably helped i got pics of the silicone but i cant seem to get them on my comp from my digital cam I ll get them on later
well anyways when i put on my other weber ran good i was workin the throttle and bam backfired right through the carb again then still works fine so i blew another power valve probably
i got the thing timed right would my points have anything to do with it they kinda are almost due again
sorry long post guys and girls
PostPosted: Tue Jan 18, 2005 11:20 pm
Back firing thru the carb is an open intake valve, which means timing. Maybe the chain is off a link or two.
Users browsing this forum: No registered users and 54 guests
