It is currently Sun Jun 07, 2026 11:47 pm
PostPosted: Mon Jan 17, 2005 8:54 pm
well i finally got arround to pulling the trans, and flywheel off. once i got the trans mounting plate pulled i found the cause of the leak that left me stranded over thanksgiving. the oil galley plug at the right rear of the engine blew out. fortunately i got the engine shut down before it caused damage to the crankshaft. although the rod bearings are all scorched. thought i'd replace all the bearings, clutch, rear main, etc. then i'll have her out on the road again.
PostPosted: Tue Jan 18, 2005 9:51 pm
oh man bum deal man well hope it wasnt your main transportation
good luck with your rebuild
PostPosted: Sat Feb 12, 2005 2:40 am
it kinda was.. right now I'm stuck driving the wifes car on every day accept wednesday then i drive my father in laws truck. which has its own issues all together. probably going to finish fixing my honda first. it only needs the wiper motor , and tail lights fixed then i can go thru the smog test.
PostPosted: Thu Feb 17, 2005 1:12 pm
Banishment Pending
aw yes the lovely smog tests that are mandated down there in the Valley
