It is currently Mon May 25, 2026 2:49 pm
PostPosted: Mon Nov 22, 2004 11:03 pm
I need to know how long the camaro driveshaft im suposed to get is because i know someone who can get them but they are lying around every where so he needs the measure'ments. Any help would be great. THANKS...
PostPosted: Mon Nov 22, 2004 11:23 pm
Well I could be wrong, but it should be-- U-joint centerline to centerline is 40-9/16". Hope its right, and hope it helps :wink:
PostPosted: Wed Dec 29, 2004 10:05 pm
LUVTruck.com's Cornholio
If you have a shortbox and wanna put a v8 in it and want to use a camero driveshaft it'll work, but the engine has to go back a little more.
PostPosted: Wed Dec 29, 2004 11:03 pm
Im using a saginaw 4-speed tranny. Dont know if it is the same length as the th350.
PostPosted: Wed Dec 29, 2004 11:21 pm
hmm dont know either
PostPosted: Wed Dec 29, 2004 11:54 pm
if i remember correctly it is the same length, if you are using the saginaw from the 60's thru early '80's. I am not sure of the splines for the yoke though. can anyone else verify?
