It is currently Sat Jan 31, 2026 3:39 pm
PostPosted: Mon Dec 06, 2004 2:06 pm
Has anybody had any luck finding a diagram for a injection pump to a 81 diesel luv 4x4....the manual i have does not one and need to find a diagram that lists all the parts fpr it.....thanks in advance...
PostPosted: Mon Dec 06, 2004 2:43 pm
let me check my manual tonight when I get home and see if it has what you are looking for. If so, I'll scan it up and e-mail it to ya. My manual will just have an exploded view and part numbers, if that will help.
 Post subject: Diagram
PostPosted: Mon Dec 06, 2004 3:03 pm
Hello. I would like a diagram of the pump as well . TIA :)
PostPosted: Mon Dec 06, 2004 3:11 pm
can do :wink:
PostPosted: Mon Dec 06, 2004 6:40 pm
i looked in my manual and it shows a minimal breakdown of the pump, mostly the fittings and such that are removeable. It does not show the full breakdown. I can still scan and sent it if you guys like. Just let me know...
PostPosted: Mon Dec 06, 2004 6:45 pm
Yeah if you would BOB that would be very helpful......also would happen ti know what the oil hooking to the back of the vacuum oumo is for or called damn thing starting leaking oil out of it.....and this manual i payed 70 bucks for is useless.....
PostPosted: Mon Dec 06, 2004 11:15 pm
Good luck on finding a break-down of the Bosch injection pump. This is a unit that has to be sent to a rebuild center to be repaired. I guess they figure it's way too precise for the average Joe to ever think about repairing. :roll:
Bona Fide diesel fanatic.
Kubota B6100 HST diesel
PostPosted: Tue Dec 07, 2004 12:03 am
Hey Zachary actually the diesel shop in oregon rebuilds them........in the same city i am in.......but thanks a bunch for the info...
PostPosted: Tue Dec 07, 2004 10:40 pm
Slick--
There is a soft cover book that has an excellent chapter (21 pages) on the Bosch pump used on the Isuzu C223. It has lots of diagrams and explanations about how it all works. This is a 20 year old book but maybe you can find one. I think there may be others as well but this one is good.
AUTOMOTIVE DIESELS by Edward Ralbovsky
Copyright 1985 by Delmar Publishers, Albany, New York
This book has a chapter on injectors as well. Good stuff. Hope you can find one.
Paul
'84 Isuzu diesel P'up
PostPosted: Tue Dec 07, 2004 10:50 pm
Slick & All--
Flash! I just did a Google and found that Amazon claims to have the above tiltle at $75. Ouch! But it is worth it if you NEED to know about this stuff. Go for it.
Paul
PostPosted: Wed Dec 08, 2004 1:18 pm
Alright thanks Turbo will look into it and see if i can find one
PostPosted: Tue Dec 28, 2004 8:41 pm
I have an original OEM GM diesel LUV engine manual. I'll look to see if it has a diagram..
PostPosted: Tue Dec 28, 2004 9:20 pm
If you do would be possible if you could scan it and send it to me if possible...Im losing the prime and have to prime it every morning.....not sure if I have a bad seal on pump or filter is leaking.....or maybe a hole in a fuel line....not quite sure....
PostPosted: Tue Dec 28, 2004 9:28 pm
Sorry, I don't have a scanner. I had the same problem with my truck and the main fuel line had a slight cut in it. My cab had sagged and rubbed a hole in it.. I just put a rubber line in there and haven't had any problems since..
