It is currently Fri Mar 20, 2026 12:28 pm
 Post subject: power steering
PostPosted: Sun Jun 23, 2002 8:50 pm
I have a 1978 luv and was wondering can power steering be installed on this and what power steering unit would I use?
PostPosted: Wed Jun 26, 2002 11:09 pm
I dont know of any luv truck that has Power steering :? I will try to see if i know of anybody around SoCal 8) that knows of a way to do this,Later,Michael
PostPosted: Thu Jun 27, 2002 2:34 pm
thanks michael any info will be better then what I have....none!
PostPosted: Sat Jun 29, 2002 12:46 pm
I don't belive any of these trucs had power stering. and wuoldn't cnsider adding it either
PostPosted: Mon Jul 01, 2002 9:41 pm
No luvtruck came with power steering from the guys i talked to :(
I dont think you need it they dont turn that hard anyways.Sorry i couldnt help you,Later Michael
PostPosted: Tue Jul 02, 2002 4:50 pm
I understand the last year the luv was built 82 (series 12) had power steering.
PostPosted: Wed Jul 03, 2002 8:05 pm
I think the '82 is a different body style though, isn't it?
I'm going to the junkyard again this weekend. I'll see if they have any newer ones with power steering.
If at first you don't succeed, try it like your wife told you to do it.
 Post subject: re powersteering
PostPosted: Thu Jul 18, 2002 1:57 pm
i own a 81 chevy luv deisel and it has power steering it makes all the difference
PostPosted: Thu Jul 18, 2002 3:15 pm
I own a 1982 Chevy LUV diesel and it does have power steering. Hey mule that is cool that you have a 1981-1982 series LUV. Yes, the body style is different for the 81 and 82 LUV. The truck is an exact look a like to the 1981-1987 Isuzu PUP. Mule is your truck a shortbed or longbed? I am in need of a longbed pickup bed for my truck that is in good condition. Also if you have any pictures of your truck can you let me know and send them to my email. When these trucks are custom done they look sweet.
 Post subject: Re: power steering
PostPosted: Fri Aug 23, 2002 4:35 pm
I'm sure the NEW LUVS have power steering...
PostPosted: Sun Aug 25, 2002 11:05 am
I don't know how bad you want power steering, but Wilwood used to sell a kit to add power steering to any car. As you can guess, it was very expensive.
I was considering putting it on mine way-back-when.
PostPosted: Tue Oct 15, 2002 9:44 pm
i have 7 luvs and one is a v8 witch i had to have power steering on u can do it its not that hard u get a power steering box from an isuzu trooper 80s it bolts to the frame but there are 2 things that u have to fab u have to add a u joint on the steering coulum and shorten it a couple of inches and there is the pitmen arm witch us luv guys know has that stupid two hole arm so what i did because the splines on the arms were different i had a machine shop cut and weld the two pecies they tested the arm in a 5 ton press and it didnt break i have had no problems with the set up and strongly sugest doing it its really nice to drive
 Post subject: sttering
PostPosted: Mon Oct 21, 2002 9:08 pm
just converted my dads luv to power steering all the trooper steering bolts right on get every thing idler draglink tie rods every thing dont weld a pitmen arm i will probably change my other set up
mike8cyl
Users browsing this forum: Bing [Bot] and 34 guests
