It is currently Sat Dec 13, 2025 2:59 pm
 Post subject: Vacuum Pump
PostPosted: Mon Dec 06, 2004 7:38 pm
Just got my truck back and i noticed it started knocking and my idiot light for oil pressure came on and I find this hose hooked to my vacuum pump...anybody have any ideas if this is just a normal hose that can be replaced or is it special.
Here is a pic sorry its so big :oops: ....its the hose coming of the back of it with the black spot...thanks in advance
Here is a link to it
http://us.f2.yahoofs.com/bc/40e23f71_beb2/bc/My+Documents/diesel.jpg?bfaSiwBBSediXIrm
PostPosted: Mon Dec 06, 2004 8:32 pm
hhmmm does it go anywere, say the brake booster?
PostPosted: Mon Dec 06, 2004 8:35 pm
the line comes from the bottom of the block to the center of the vacuum pump...Then there is another hose on the side that goes to the brake booster...one that is leaking oil comes from the block to the center of vacuum pump...
PostPosted: Mon Dec 06, 2004 8:52 pm
i wish i was outside now... hold on let me take a feild trip to my luv-mobile
PostPosted: Mon Dec 06, 2004 9:00 pm
let me whip out chiklin's i mean uhh... chiltons...
ok, the book only talks about the PVC sys on the truck, we just have a vent from the crankcase... i'm not really sure what it's for, too dark out... and it's rainin...
PostPosted: Mon Dec 06, 2004 9:01 pm
alright thanks
PostPosted: Mon Dec 06, 2004 10:05 pm
The vacuum pump on your motor is lubed with crankcase oil. One line comes from the oil gallery with pressure to go to the vacuum pump, and another returns it to the sump. A third line is for the vacuum itself.
This is what the P'up came with, anyway, as the vacuum pump was on the back of the alternator.
You can pump the engine dry of oil if the feed or return lines aren't attatched.
Just my 2¢. :)
Bona Fide diesel fanatic.
1994 Chev S10 Ext Cab Isuzu Diesel 5spd
Kubota B6100 HST diesel
PostPosted: Mon Dec 06, 2004 10:07 pm
Thanks a bunch that answers alot for me just need to find out if it is high pressure line so i can get it replaced....
PostPosted: Tue Dec 07, 2004 7:25 pm
Ok i need some help here....I need to find this pipe for my vacuum pump that goes to mu block.....the dealership quit making the parts in 1993.....and havent been able to locate one in a wrecking yard...HELP plz....
Or any tips on how to repair....the pipe is broke inside the metal mesh or whatever it is and dont have a clue at this point 8O
PostPosted: Tue Dec 07, 2004 9:10 pm
Slick--
The pressure oil feed line to the vacuum pump has banjo fittings on each end. These can be removed and a new piece of hose crimped on to be as good as new. We have an industrial hardware store here where I live that does this stuff.
Hopefully you can find a place in Oregon that can do it. While you are at it have them make it about an inch longer as the line can get bent too sharply when one adjusts the alternator.
Paul
'84 Isuzu diesel P'up
PostPosted: Tue Dec 07, 2004 10:37 pm
Thanks a bunch will look tomorrow for a shop that can do this for me....
PostPosted: Wed Dec 08, 2004 3:53 pm
Posted: Fri Jan 16, 2004 12:20 pm    Post subject:
I had to replace my oil line that runs to the back of the alternator this past summer. The following infomation was found by doing an author search for all of my posts "woody"
Good thing this is you can still get the part from Isuzu, bad thing it costs alot for a small item and it takes a couple of weeks to get it. Now that they are all on computers, they don't have tech data on the Diesel Luv, so I had them refrence the Isuzu Pup truck, that was in production till 1986-87? or try cross refrencing the Tropper, since that diesel engine used the same setup.
From an early post:
I just bought this truck a month ago, was changing the alternator belt and caused the oil line to go bad.
Any idea on where to get the parts to fix it? The part number is (94028195)?
The hose has two banjo fittings, one is 12mm the other is 17mm. The 17mm side conects to the pump, the 12mm connects to the block.
I know it sounds wierd that an oil hose is connected to the alternator, but this is a special alternator which has a vacuum pump that is specially for the diesels. I can get a hose made by a local auto parts store, but as for myself making the hose myself, I don't have the capabilities and right tools/machinery. I will try to get a brand new one from the dealer, which is the best way to handle the problem with the leaking
from an earlier post
The oil line that routes to the the back of the alternator is used to keep the vacuum pump oiled and cooled.
The Vacuum pump is mounted to the back of the alternator (diesel englines do not create a lot of vacuum) to produce vaccum to run the brake booster.
Hope this helps
BTW to find that little oil line with banjo fitttings you have to order it directly threw Isuzu. It will cost you about $45.00, and $2.00 for the banjo gaskets.
It you just need to change the alternator or belts REMOVE THE HOSE! or it willl brake since the line was soft , over time it gets hard from the heat and will brake.
1981 Chevy LUV 4x4 2.2L Diesel 4 Speed Selling out moving over to VW TDIs.
PostPosted: Wed Dec 08, 2004 8:51 pm
Thats what happened got it back from the shop and had redo all there work and tighten the alternator and then that line started to leak.
Well will see if i can find one if not will order one
Thanks
:D
PostPosted: Thu Dec 16, 2004 6:14 pm
Ok Guys really need some help here.....the hose i need with those banjo fitting I cannot find a shop here where im at that will recrimp these things on a new hose....I need some help finding one as soon as possible have to it for christmas to take my little to her grandparents for christmas...thanks all
PostPosted: Thu Dec 16, 2004 10:24 pm
I don't know if you want to try this but would you be interested in going to the Isuzu dealer for the hose? I think I would try to go to the dealer, as my local Isuzu dealer has very reasonable prices on new parts for my 1982 LUV and it is 20+ years old. If not, try your local Chevrolet dealer for the hose. If you want, I can get you the part number for that exact oil hose because I have a 1972-1982 Chevrolet LUV microfiche. Now my opinion is the Chevrolet dealer won't be as reliable as the Isuzu dealer when it comes to new parts for the diesel trucks and that is why you will need a part number for the Chevrolet dealer. As long as you have the part number I can't seem them turning you down and hopefully they can get you one. If your interested in the Chevy part number, please let me know and just reply back here.
PostPosted: Fri Dec 17, 2004 12:28 am
I would have to agree Isuzu would be more reliable cause Chevrolet dealership here has been totally un helpful...they wont even talk to me about my truck......Which I think is pretty stupid considering they meade the truck in conjunction with Isuzu if im not mistaken but sent pm luvdiesel thanks
PostPosted: Fri Dec 17, 2004 5:27 am
Check the 4x4wire.com forums and try to find Jerry Lemond. (JLEMOND I believe) He will know where to point you for one. You could also call the parts dept at St Charles Isuzu. They have a great rep with the Isuzu guys at 4x4wire for finding the most obscure parts. Find them at http://isuzu.stcharlesauto.com/ and hit the contact link for a phone number or put in a parts request at the parts link. I hear "Merlin" in parts is THE person to talk to.
PostPosted: Sun Dec 19, 2004 10:21 am
Well I got it fixed....Was unable to locate one..So used 300lb high pressure transmission line and repaired the crack and it works great...Thanks all for the help :P
PostPosted: Tue Dec 28, 2004 8:39 pm
Darn. I read this too late. I have the OEM line you need. I picked it up at the Isuzu dealer years ago. The parts guy laughed when I bought it since they actually had it in stock.. :)
PostPosted: Tue Dec 28, 2004 9:18 pm
Let me know how much you want might be it off of you......if you want to sell it...I really dont like to modify something like that......But it seems to holding at the moment......
