It is currently Thu Feb 19, 2026 6:31 am
PostPosted: Sun Nov 21, 2004 10:52 pm
I"m trying to get an oil seal for my 80 Luv 4x4, its the seal just above the ilderarm (fits inot the ilderarm bracket)
I have a shop bok parts listing, so here is the orginal parts number:
94020132
I tried to search online too, but havent had much luck.
THe inside diameter: .75
Outside diameter: 1.255 or 1.260
Napa has tried, but the close thing they can come up with the outside diamter is 1.37
PostPosted: Sun Nov 21, 2004 11:06 pm
You might try Advance Auto Parts, if you have them in your area. I have had better luck finding new replacement parts for my luvs thru them than anywhere else :wink:
PostPosted: Mon Nov 22, 2004 4:22 am
I'll check the giant seal interchange book my Dad has and see if I can come up with anything. I think it has listings by size and that would at least get you some part numbers to try for. It might be a couple days before I get over there though.
Failing that, you could try St. Charles Isuzu at http://isuzu.stcharlesauto.com/ Hit the parts link, or call them using the number on the contact us link. They have an excellent reputation on a lot of the Isuzu boards for getting hard to find parts and giving you a good deal on them If you have the Isuzu parts number, they will have a good chance of being able to track one down for you. You could also try your local Isuzu dealer, though they tend to be hit or miss whether or not they have anyone that actually knows their parts from a hole in the ground. That is assuming there even is a "local" dealer around your area.
PostPosted: Mon Nov 22, 2004 7:53 am
Luvtruck.com Wookie
there's a machinest in placerville (hinds custom machine) that has and can get anything you need seal wise, give him a call....he's listed in the yellow pages.
TiLtEd wrote:
Boobies!!! :D
 Post subject: find seal
PostPosted: Thu Nov 25, 2004 3:58 pm
I am trying one more time with napa, this time I talked to a guy who has been there a long time and monday i will find out if it can be pressed into
the housing. Thanks for all your help! 8)
PostPosted: Tue Dec 07, 2004 12:21 am
I went there, He can't find th seal himself, but has suggested a few business to try. I emiailed Rare parts in Stockten, Ca, they speclize in
suspension and even go back to the Ford Model A for parts.
Anyone else, gone through the steering for th e 4x4 Luv and had to replace the oil seal?
PostPosted: Tue Dec 07, 2004 12:22 am
