It is currently Thu Mar 26, 2026 3:20 am
 Post subject: Help
PostPosted: Thu Nov 18, 2004 10:11 pm
will you tell me how easy it is to shave the little groves in the cab???Image[/img][/url]
PostPosted: Thu Nov 18, 2004 10:50 pm
Where do you want to shave the little grooves in the cab exactly? Need more information. :wink:
PostPosted: Thu Nov 18, 2004 11:24 pm
I assume you're talking about the vent slits to the rear of the door openings?
It shouldn't be difficult. a couple ways would be to cut out around them, make a template of it, cut out a piece of sheet metal to match, test fit, tack it in place, check it weld it (keep it cool or it'll warp) a little grinding, maybe a skim of filler, prime done.
or
just grab a tub of Bondo and fill it all in. :)
There are people here that have done this and can probably give some better instruction...
Resident lurker
 Post subject: Bondo
PostPosted: Sat Nov 20, 2004 12:36 am
or
Maybe by shave, he means strip the paint.When I sanded my truck and primered it, and those vent areas, I coudnt really get in there that well.
As far as Bondo goes, I have a dislking to that stuff, it doesnt last that long, it ususlay crack and the paint goes with it, makeing it look awful.
I saw replace it with steel. Heck you can get metal rocker arm replacements.
PostPosted: Thu Nov 25, 2004 10:37 pm
I think the vents are cool looking. It makes a Luv look more like a Luv. I would leave it.
PostPosted: Fri Nov 26, 2004 12:51 pm
hey thanks for the imput guys
PostPosted: Mon Nov 29, 2004 7:13 pm
shave them bitchs off defintily!!! Just cut em off and get some sheet metal and weld that on then hit it with a grinder it should be easy as cake
PostPosted: Mon Nov 29, 2004 9:22 pm
When I redo my LUV I am shaving pretty much everything EXCEPT those vents. IMO that is one of the defining features of the 72-80 LUV!!!
But if you are going to do it, the best and easiest way to do it, like mentioned before is to cut them out and weld in a patch panel. :wink:
