It is currently Sun May 10, 2026 7:07 am
 Post subject: rear tires sizes
PostPosted: Wed Nov 24, 2004 2:05 am
whats is the biggest 15 inch tire that will fit under the back of the truck
PostPosted: Wed Nov 24, 2004 3:14 am
We talking width of tire that will tuck or the tallest tire? With 4x4 owners and V8 luv owners, there are two different kinds of big tires. :)
I had 235/75R15 tires under the back of my 4x4 luv with zero lift, though I didn't run it much on the road. Bigger will fit, but if you offroad at all much bigger tires will rub with much of a bump/rock on one side. I managed to rub 195/75R14s (original stock size) on a stock 2WD once or twice, so anything will hit if you give it a enough effort.
If you are talking about width, I'm sure someone else will have an answer for you.
PostPosted: Wed Nov 24, 2004 11:15 am
LSX LUV Owner
i got a 255/60/15 under the back of my truck.. stock height it didnt rub, but dropped 2" it rubs on big bumps.. but i can pull on the fenderwells some and pull it out some..
heres a pic of it to kinda show how much of the wheel well it fills up..
PostPosted: Wed Nov 24, 2004 12:22 pm
I had a 31x10.5 inch mudding tire on the back of my LUV at one point. Just to see how goofy it looked :lol: But they honestly did fit. No alterations or anything to the rear end, stock height, 2wd. 1981 model..
PostPosted: Wed Nov 24, 2004 12:37 pm
i got 31/10.50/15 tires on my 4xluv right now and the dont rub, i used to have 30/11.50/15 thrnbirds on it, those never rubbed.
Currently no more luv's... But in search of one!
PostPosted: Wed Nov 24, 2004 4:35 pm
i manged to put a 33X14.50R15 inch super swamper bogger tire on my truck looked really cool filled up the the fender and stuck out a bit but if you hit a bump it will rub so i didn't drive it with that on. :lol:
 Post subject: thanks
PostPosted: Wed Nov 24, 2004 6:46 pm
thanks every one...............thats what i was looking for
PostPosted: Mon Nov 29, 2004 7:21 pm
what is the largest tire/rim combo that will fit on a stock 1980 luv 2wd
Users browsing this forum: Google [Bot] and 21 guests
