It is currently Tue May 26, 2026 6:47 am
PostPosted: Tue Nov 09, 2004 3:40 pm
Last night I got to put in my 2inch blocks in the rear and I lowered the front roughly 1 or 1 1/2.The front sits about a quarter inch from the bumpstops.Before I lowered the front it had about 1 inch of travel and it rode really soft.If I shorten the bumpstop to get back an inch of travel will it ride the same as it did before I lowered it?Will I need an alignment if its under a 2 inch drop in the front?I cant drive the truck because they gave me the wrong size nut in the block kit for the u bolt.I will get some pics up after I get to drive it.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Nov 09, 2004 8:25 pm
i lowered mine too and now i wish i hadent cuz the ride sucks now i have been thinking about cuting the bump stops but havent yet ill give it a try and get back to you
if it aint mine i dont want it
PostPosted: Tue Nov 09, 2004 9:01 pm
I would like to raise it like 3" in the back how much does a kit like that cost. no lowering for me after i read this
PostPosted: Tue Nov 09, 2004 11:59 pm
Luvtruck.com Wookie
dan..... i would get that re-aligned.......
dr luv.... add springs.... get a leaf off of a 70'sfull sized chev and add it to the stack.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Nov 10, 2004 12:01 am
Go buy some air shocks. Then you could change it if you wanted to. Thats what I put on my Chevelle.
PostPosted: Wed Nov 10, 2004 12:10 am
ya sounds good but what are they asking my figgin arm
PostPosted: Wed Nov 10, 2004 12:14 am
I wouldnt think more than $50 a set. I might even look on ebay
PostPosted: Wed Nov 10, 2004 12:17 am
nice so like napa or sumthin or just like a shock store
PostPosted: Wed Nov 10, 2004 12:21 am
ya ya!
PostPosted: Wed Nov 10, 2004 12:23 am
coo!! coo!!!
PostPosted: Wed Nov 10, 2004 1:55 pm
You can cut the bumpstops but your ride will not be exactly the same as it was. I would cut the bumpstops to get some travel, then get a set of lowered shocks which are slightly stiffer than stockers to make up for the decrease in tension on the front end. It should ride fine like that :D
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Wed Nov 10, 2004 2:56 pm
I'll look into some new shocks, I noticed the front's are bottomed out 8O
Thanks for your help guys 8)
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Nov 11, 2004 9:35 pm
take the bump stops out, and get it aligned
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Thu Nov 11, 2004 9:44 pm
This is an option too but if you take the bump stops all the way out, Get some old inner tube or something to attatch to the bump stop bracket or you will get a loud banging sound when you bottom out. You should definitely get it aligned one you are satisfied with the stance or you will chew up tires big time :D
PostPosted: Thu Nov 11, 2004 10:17 pm
plasma cutter fixes loud banging
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Sat Nov 13, 2004 9:11 pm
well thanks for clearing that up :roll:
Most people don't have a plasma in their garage and the ones that do would probably not ask a question like this one. I was just giving him an option:wink:
PostPosted: Sun Nov 14, 2004 10:23 pm
LSX LUV Owner
i removed all my bumpstops.. havnt had bump stops on it since well after v8swap and it was back on ground and the rear.. i hadbump stops on it.. lowered it 2" and it was like 1/2" from bumpstops.. rode like crap, took bumstops off and rides like it did before lowered.. i dont think it rides bad...
Users browsing this forum: No registered users and 63 guests
