It is currently Fri May 01, 2026 4:48 pm
 Post subject: fuel pump
PostPosted: Fri Nov 12, 2004 2:16 pm
would it help during the winter to keep the fuel pump warm? wher is it anyways? thanks new ownr 81 diesel
PostPosted: Fri Nov 12, 2004 8:47 pm
unless you live where it gets realy cold then no. gas dont freeze until i think -100's if your talking about somthing else then ill shut up
PostPosted: Fri Nov 12, 2004 8:50 pm
Dr. Luv wrote:
ill shut up
WHEN :?: :rofl:
PostPosted: Fri Nov 12, 2004 8:54 pm
lol
PostPosted: Fri Nov 12, 2004 9:00 pm
read this...Diesel
hope you have acrobat or something to read pdf's
some info on some winter problems.
Resident lurker
PostPosted: Sat Nov 13, 2004 8:35 pm
If you live in a climate where fall and winter are cold (0-30 degrees) than keeping the fuel pump warm is only better for operating your diesel truck. I remember one time in the winter where it was really cold out and I had a hard time starting my truck. I got it started and then proceeded to drive it down the road, went about 4 miles and then it began to loose power and I didn't know why. Turned out the diesel fuel in the tank was geled up because of the cold and I wasn't getting fuel to the engine. Had to wait later in the day during the afternoon to drive it, after the day warmed up I got back in and it drove regular. Finally, the fuel filter is located above the injection pump and pretty close to the passenger side of firewall.
