It is currently Mon Jun 08, 2026 5:27 am
 Post subject: ratio test
PostPosted: Thu Nov 11, 2004 10:06 am
i tried to figure the gear ratio on the 4x4 to see if they are 4.56 i know its been said they have 4.10
so i did the test where you mark the tire and driveshaft and spin the tire 360 degree and see how many turns it moves driveshaft but it only moved it 2 and 1/4 turns which would mean 2.25 i know that isnt right
PostPosted: Thu Nov 11, 2004 2:48 pm
I am assuming that you have a stock rearend (this is a "open" type verses a "posi" or "locking" differential) and you jacked only one side up when you rotated the tire. Because it is an open differential you must fully rotate the tire twice to get the estimated gear ratio. Since you measured only 2.25 drive shaft turns with one tire revolution I would say you are closer to a 4.56 ratio than a 4.10.
PostPosted: Thu Nov 11, 2004 11:24 pm
o ok cool so the haynes manual is right 4.56 sweet i was just stumped on that
thanks for the help Kane
