It is currently Sun Mar 29, 2026 9:19 am
 Post subject: Fuel cell mounted
PostPosted: Mon Dec 30, 2002 8:59 am
I finally took a picture of the fuel cell mounted in the truck.
I need to paint the straps and mount the fuel pump now.
here is the link
http://www.angelfire.com/tn2/xr50freekz/luvbuild.htm
any comments or suggestions will be appreciated.
03Cobra
PostPosted: Mon Dec 30, 2002 1:47 pm
Nice....what size and brand of fuel cell is that ? Does it hang down below the rear end or does it tuck up under the bed all the way ? I'm just curious because i was thinkin about doin the same.
PostPosted: Mon Dec 30, 2002 2:22 pm
That is one sweet setup. :D That's like a 16 gallon, right? Way to go :P
PostPosted: Mon Dec 30, 2002 4:01 pm
looks nice, whats it made out of?
just figured id ask a question too :lol: :P
seriously, looks sweet man. hope i get to see it someday
PostPosted: Mon Dec 30, 2002 4:30 pm
So, where are you going to put your spare tire? :P
Just kidding!
Very nice. I'm going to follow your lead and do the same. What were the diminsions of the cell?
Thanks,
Mike
PostPosted: Mon Dec 30, 2002 5:50 pm
i don't know if you plan on racing but if you do i believe you have to have that boxed in. but that does look sweet like that. i'll track down my nhra rule book and let you know. terry
PostPosted: Thu Jan 02, 2003 12:31 am
its true -you do have to box the tank if hangs below the frame,if you make the box of steel it should be .024 or.032 aluminum,page 194 nhra rule book.i used 032steel for my box !
PostPosted: Thu Jan 02, 2003 2:45 am
Hmmm, so far they haven't complained about mine.
Guess I get to redo that someday. :(
PostPosted: Thu Jan 02, 2003 7:10 am
ok it is a 16 gallon plastic JAZ fuel cell.
it will be completely under the bed. I will cut a hole and make a lid to lift for filling. it doesn't hang lower than the rear end.
LOL @ spare tire....I haven't carried a spare since 1993......guess luck has been on my side...knock on wood.
so I have to box the whole thing in? I guess if anything hits it right? well I might get around to doing it, but im sure it is more durable than the factory plastic tanks in the newer cars, so im not worrying about it for now. thanks ALOT for the info though.
03Cobra
PostPosted: Thu Jan 02, 2003 8:12 am
There very tough, they have to be boxed in to pass tech though, and race. Bryan
PostPosted: Thu Jan 02, 2003 9:10 pm
I mentioned this to someone today and they interpreted the "below the frame" rule as, it can't hang below the main frame rails. In other words, if your tires fall off, they don't want the fuel cell grinding on the ground.
So, now I'm not sure. I don't have a rulebook so I guess I need to get one.
PostPosted: Fri Jan 03, 2003 12:15 am
yes, the tank only has to be boxed , the portion under the frame .
