It is currently Sun Mar 29, 2026 9:19 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: strange sounds?
PostPosted: Mon Oct 18, 2004 9:37 pm
hey, my luv is making some pretty wierd sounds... usually only at higher rpms, around 3000+. It sounds like the sound a loose fanbelt makes, but only at a certain rpm, and ive just replaced the belts. any theories? my dad thinks it might be the carb sucking air or something.
PostPosted: Tue Oct 19, 2004 1:30 am
So is this like a squeal sort of noise? I think we may need a bit more graphic description. The more you can narrow it down, the better like if it does it only when moving or just anytime the motor hits that RPM. If it squeals as loud as a loose fanbelt, I can't think of much besides the belt that can make that sound. The stock carb doesn't make a whole lot of sound, maybe a sort of whoosh or low pitched hiss. A weber with that small square filter will make a bit more though it is still more of a whoosh/hiss.
PostPosted: Tue Oct 19, 2004 11:07 am
Maybe it ain't the engine making the sounds, guys. How about a wheel bearing?
PostPosted: Tue Oct 19, 2004 11:34 am
Luvtruck.com Wookie
my AIR tube rattles at 3000 rpm and a little at 1500, it a real high frequency,rattle that doesn't do any harm as far as i'm concerned,but annoying as ....well....
Anybody know where to get #14 1.25 pitch plugs?????
TiLtEd wrote:
Boobies!!! :D
PostPosted: Tue Oct 19, 2004 3:02 pm
what do you need the plugs for?
Resident lurker
PostPosted: Tue Oct 19, 2004 4:33 pm
I think he might be onto something, cause, yeah, its a really annoying high pitched squealing kind of sound, and happens at that rpm regardless of gear or speed... seems to be quiet down after the engine is warm.
PostPosted: Wed Oct 20, 2004 11:31 pm
Luvtruck.com Wookie
the plugs are for the AIR injection tubes........on the driver's side of my engine's head.
that's a damn annoying rattle.........as well as one of my exaust leaks.
i wish i had a dat recorder so i could play yall an audio clip of the noise.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Oct 20, 2004 11:51 pm
You're talking about where I've got my brass plugs in this pic, right?
1980 Luv Mikado 4X4
PostPosted: Thu Oct 21, 2004 5:58 am
If that is what you need, you can take the air tub off, cut the small tubes just above the nuts then weld them shut. I have 8 that I don't need and chopped just for this purpose. I need to weld them, so if you need a set I'll get 4 welded up and send them to you...
btw that's what I have in my truck and the work very well.
Resident lurker
PostPosted: Thu Oct 21, 2004 7:15 am
I got my brass plugs for like, a buck a piece at Autozone.
1980 Luv Mikado 4X4
PostPosted: Thu Oct 21, 2004 8:26 am
Luvtruck.com Wookie
those plugs arn't for sale legaly here in cali......damn smog beuracrats(sp?)
yeah narrcisist.... those plugs.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Oct 21, 2004 7:09 pm
well, they're beautiful, I love 'em.
1980 Luv Mikado 4X4
PostPosted: Thu Oct 21, 2004 7:17 pm
Luvtruck.com Wookie
they went right in without any distortion?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Oct 21, 2004 9:01 pm
Finger tightened, snugged up a half turn with a wrench and haven't thought about 'em since. Except to appreciate 'em when I look at the beat-up air manifold they relieved me of.
1980 Luv Mikado 4X4
PostPosted: Thu Oct 21, 2004 9:04 pm
If you can't find some, let me know. I owe you a favor.
1980 Luv Mikado 4X4
PostPosted: Sat Oct 23, 2004 11:34 am
Luvtruck.com Wookie
i took the air manifold off the g200 that i have sitting here and figured somrthing out. i tapped the inside of the plug and tighentened down the right sized bolt into them and it works great.....turns out the bad doughnut i thought i had was the air rail tips broken below the nuts on cyls 1-2
so now no exaust leak and no air rail either and no more rattle......
hey adem..... any luck?.... sorry we hijacked your thread.
TiLtEd wrote:
Boobies!!! :D
 Post subject: Re: strange sounds?
PostPosted: Mon Jan 11, 2010 5:34 pm
I want to resurrect this thread. what do you guys think the sound is?
PostPosted: Tue Jan 12, 2010 12:01 pm
OK, shot in the dark here.
Check belt tension first. Being too tight is just as bad, if not worse, than too loose. I had a high pitch squeal on my '73 Midget and found out it was the alternator fan belt being way too tight and burned up the bearings in it.
I beleive the engine can be cranked up and will run without theh fan belt on for a short time. Try this to see if the noise is still present. If it is, you have ruled out the alternator, water pump, and belt. If you don't hear it, then you have narrowed it down to those three things.
Let us know what you find if you try this so we can either press on or say, enjoy the ride!
Rick
Loranger, La
1980 Stepside LUV (Again)
 Post subject: Re:
PostPosted: Tue Jan 12, 2010 12:22 pm
If it was a wheel bearing it would be more of a roar. Jack up the truck, and grab a wheel, if you can wooble it or it is loose then its more than likely a wheel bearing. Are any of your fan blades bent or look out of whack, that could cause a change in pitch of the fan and cause a whinning noise as well.
1990 Chevy Suburban
PostPosted: Tue Jan 12, 2010 1:41 pm
the wheel wobble from side to side is going to be a problem in steering linkage.
wobble from top to bottom (grab top and bottom of wheel and rock it in and out) and if there is any wobble, its wheel bearings.
(learned that from my dad)
