It is currently Mon May 25, 2026 4:28 pm
 Post subject: Body Bushings AGAIN
PostPosted: Sat Sep 25, 2004 8:24 pm
Thanks for the replies I recieved before on this, but is it possible to get some pictures of each of the different body and bed mounts? I went to the local junk yards and couldn't find any two wheel drive LUVs to look at and I need to put the cab and bed on to press on with my rebuild. Even descriptions of the assembly and position would help, ie front of cab at radiator: top down, cab, washer, rubber, spacer, chassis, washer, nut. Any help would be appreciated. Thanks.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Fri Oct 15, 2004 7:57 pm
I'm using hockey pucks,bore a hole and grind a little off the outside and ther going to work fine. Maybe just a little thicker
PostPosted: Fri Oct 15, 2004 8:16 pm
These are the mounts for mine with a 3" body lift. The ones on the body are like the one by the tire in the second picture. I'll take a picture of the front tomorrow.
1980 Luv Mikado 4X4
